Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5093 Cmd Rej: TIF NS feature cannot be Enabled unless MATCHSEQ is DN
The matchseq=dn parameter must be specified (see the chg-tifopts command) before the TIF Number Substitution feature can be enabled.
Recovery
  1. Display the status of the matchseq parameter. Enter the rtrv-tifopts command.
  2. Configure the matchseq parameter as necessary. Refer to the command description for the chg-tifopts command in the Commands User's Guide and to the TIF User's Guide for assistance.
  3. Re-enter the enable-ctrl-feat command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
