Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5092 Cmd Rej: NSCgPN and SNSCgPN SAs are mutually exclusive
The Action Set specified by the asn parameter cannot contain both the NSCGPN and SNSCGPN Service Actions.
Recovery
  1. Display the Service Actions contained by the Action Set. Enter the rtrv-npp-as command.
  2. Configure the contents of the Action Set as desired. Refer to the Numbering Plan Processor (NPP) User's Guide and the feature manual for the feature of interest for assistance.
  3. Re-enter the ent/chg-npp-srs command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
