Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2334 Cmd Rej: DPC defined as linkset APC or SAPC
The specified destination point code cannot already be defined as an adjacent point code or a secondary adjacent point code.
Recovery
  1. Display the adjacent and secondary adjacent point codes. Enter the rtrv-ls command.
  2. Delete the point code as desired. Refer to the Database Administration - SS7 User's Guide for assistance.
  3. Re-enter the dlt-dstn command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
