Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2335 Cmd Rej: CLLI is not identical to that of matching Destination
The value specified for the clli parameter must match the value of the clli parameter specified for for the destination.
Recovery
  1. Display the clli value for the destination. Enter the rtrv-dstn command.
  2. Revise the clli value if desired. Refer to the Database Administration - SS7 User's Guide for assistance.
  3. Re-enter the ent/chg-ls command that generated this error message, specifying a valid combination of parameters.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
