Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5045 Cmd Rej: At least one card with IPSG GPL must be IS-NR
At least one card must be running the IPSG GPL and must be in the IS-NR state before a value of ipsg or all can be specified for the gpl parameter.
Recovery
  1. Determine the status of cards in the system. Enter the rept-stat-card command.
  2. Configure the cards as necessary. Refer to the Database Administration - IP7 User's Guide for assistance.
  3. Re-enter the chg-eisopts command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
