Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5047 Cmd Rej: Incorrect Alternate RI Mate is specified
The value specified for the mrnset parameter must already be associated with a MAP Set.
Recovery
  1. Display the MAP Sets associated with the MRN Sets. Enter the rtrv-mrn command.
  2. Re-enter the dlt-map or dlt-mrn command that generated this error message, specifying a valid combination of paraemeters. Refer to the command description in Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
