Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3602 Cmd Rej: Failure reading VLR Roaming Table
Failure reading VLR Roaming Table in the ent-vlr-roaming, chg-vlr-roaming, rtrv-vlr-roaming, and dlt-vlr-roaming commands.
Recovery
  1. The DB should be repaired or restored using the chg-db: action=repair/restore command.
  2. Re-enter the command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
