Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3603 Cmd Rej: VLR length is out of range. Range: 1....5
The VLR number in a VLR profile can not be longer than 5 digits.
Recovery
  1. Change the VLR number to 1-5 digits when entering the string of digits in the VLR Profile table.
  2. Re-enter the command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
