Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4402 Cmd Rej: SETTYPE must be CDGTA/MBR Type when NETDOM=CROSS
For the ent/rtrv-gttset command, if the netdom=cross parameter is specified, then the value specified for the GTT set type (settype) parameter must be cdgta.
For the chg/ent/rtrv-gttset command, the netdom=cross parameter can be specified if the existing GTT set type (settype) parameter is cdgta/imei/imsi/msisdn/vlrnb/smrpoa/smrpda.
Recovery
  1. For the chg-gttset command, display the existing values for the settype parameter. Enter the rtrv-gttset command.
  2. Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
