Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3741 Cmd Rej: If TIMER is specified, TVALUE must be specified
If the timer parameter is specified, then the tvalue parameter must be specified.
Recovery
Re-enter the chg-uaps command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - IP7 User's Guide for assistance.
