Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3740 Cmd Rej: If AUTO=yes, Then Duplex and SPEED are not allowed
If the auto=yes parameter is specified, then the duplex and speed parameters cannot be specified.
Recovery
Re-enter the chg-ip-lnk command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - IP7 User's Guide for assistance.
