Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3825 Cmd Rej: New CIC range overlaps an existing routing key
The value specified for the new circuit identification code range (ncics-ncice) cannot overlap an existing routing key.
Recovery
  1. Determine the overlapping ranges. Enter the rtrv-appl-rtkey command, specifying the new CIC range.
    This information is shown in the CICS and CICE fields of the output.
  2. Re-enter the chg-appl-rtkey command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - IP7 User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
