| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The value specified for the ncics parameter must be less than or equal to the value specified for the ncice parameter.
Recovery
Re-enter the chg-appl-rtkey command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to Database Administration Guide - IP7 User's Guide for assistance.
