Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3682 Cmd Rej: GWS and LNP must be ON before TLNP can be ON
The LNP and Gateway Screening features must be turned on before the Triggerless LNP feature can be turned on.
Once a feature that is controlled using a feature bit has been turned on, it cannot be turned off.
Recovery
  1. Display the status of the LNP and Gateway Screening features. Enter the rtrv-ctrl-feat and rtrv-feat commands, respectively.
    If the feature does not appear in the rtrv-ctrl-feat command output, then the feature is not enabled. If the feature has a status of off, then the feature is enabled but is not turned on.
    The LNP feature is "turned on" when an LNP ported TNs quantity is shown in the output.
  2. Turn on the LNP and GWS features as necessary. Refer to the ELAP Administration and LNP Feature Activation Guide and the Database Administration - GWS User's Guide for assistance.
  3. Re-enter the chg-feat command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
