| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
For the chg-gws-actset command, the Triggerless LNP Feature (TLNP) must be turned on before a value of tlnp can be specified for the act1 - act10 parameters.
For the chg-lnpopts command, the TLNP feature must be turned on before the jipprv or jipdigits parameter can be specified.
Once a feature that is controlled using a feature bit has been turned on, it cannot be turned off.Recovery
