Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5411 Cmd Rej: LOC is valid with HISTORY, TPSCOST, or PEAKRESET set to YES
For the rept-stat-iptps command, if the loc parameter is specified, then the history, tpscost, or peakreset parameter must be specified.
Recovery
Re-enter the rept-stat-iptps command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and the Database Administration - IP7 User's Guide for assistance.
