Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5410 Cmd Rej: Command supported only for IPSG linksets
The linkset specified by the lsn parameter must indicate an IPSG linkset.
Recovery
  1. Display the linkset configuration. Enter the rtrv-ls:lsn= command.
    An IPSG linkset will show YES in the IPSG field.
  2. Revise the linkset data as necessary. Refer to the Database Administration - IP7 User's Guide for assistance.
  3. Re-enter the rept-stat-iptps command that generated this error message.
