E2789 Cmd Rej: AMGTT/AMGTT CdPA Only/AMGTT CgPA Upgrade must be ON
The AMGTT, AMGTT CdPA Only, or AMGTT CgPA Upgrade feature must be ON before any of the parameters in the chg/ent-gtmod commands, except for the ntt parameter, can be specified.
Recovery
Display the status of controlled features in the system. Enter the rtrv-ctrl-feat command.
If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled, but is not turned on.
Enable the desired feature as necessary. Refer to the Database Administration - GTT User's Guide for assistance.
Re-enter the command that generated this error message.
If this error message appears again, contact My Oracle Support. See My Oracle Support (MOS).
