Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2126 Cmd Rej: Invalid linkset type for card
The linkset type must be valid for the card:
  • The linkset adjacent point code (APC) type must be the same as the card application type (ANSI or ITU).
  • IPSG-M2PA linksets cannot contain IPGWx and IPSG-M3UA link types during transition. After the linkset is transitioned to IPSG-M2PA, only IPSG-M2PA and IPLIM links can be added to the linkset.
  • IPSG-M3UA linksets cannot contain SS7IPGW, IPGWI, and IPGHC link types during transition. After the linkset is transitioned to IPSG-M3UA, only IPSG-M3UA links can be added to the linkset.
Recovery
  1. Verify the card applications. Enter the rtrv-card command.
  2. Verify the linksets and their APCs. Enter the rtrv-ls command.
  3. Verify the domains of the APCs. Enter the rtrv-dstn command.
  4. Re-enter the ent-slk command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide, and to Database Administration - SS7 User's Guide (for an SS7 link) or to Database Administration - IP7 User's Guide (for an IP link) for assistance.
    Contact My Oracle Support if this error message occurs again. See My Oracle Support (MOS).
