Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2127 Cmd Rej: L2 timer not valid for the signaling link type
The L2 timer range must be valid for the type of signaling link being provisioned. Refer to the command description in Commands User's Guide for the valid ranges.
Recovery
  1. Verify the APC of the specified linkset that generated this error message. Enter the rtrv-ls command.
  2. Verify the application assigned to the card that generated this error message. Enter the rtrv-card:loc= command.
  3. Re-enter the ent-slk command that generated this error message, specifying a valid combination of parameters. Refer to the Database Administration - SS7 User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
