| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The command was entered while the MASP was re-initializing.
Loading mode support denies the execution of LNP database change commands when the system is in an unstable loading mode. An unstable loading mode will result in all STP or LNP database update commands being rejected.Recovery
Re-enter the command that generated this error message after the MASP has re-initialized.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
