Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4702 Cmd Rej: MNP SMS must be ON or MO/MT SMS feature must be enabled
The Portability Check for Mobile Originated SMS (MNPSMS) feature must be turned on or one of the following features must be enabled before the ent-home-smsc command can be entered:
  • MO SMS IS41-to-GSM Migration
  • MO-based GSM SMS NP
  • MO-based IS41 SMS NP
  • MT-Based GSM SMS NP
  • MT-Based IS41 SMS NP
Recovery
  1. Display the status of controlled features in the system. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled but is not turned on.
  2. Enable or turn on the desired feature. Refer to the appropriate feature manual for assistance.
  3. Re-enter the ent-home-smsc command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
