Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4703 Cmd Rej: MNP SMS, MO/MT SMS NP or MO SMS IS412GSM Migr must be enbld
One of the following features must be enabled before the dlt/rtrv-home-smsc command can be entered:
  • MO SMS IS41-to-GSM Migration
  • MO-based GSM SMS NP
  • MO-based IS41 SMS NP
  • MT-Based GSM SMS NP
  • MT-Based IS41 SMS NP
  • Portability Check for Mobile Originated SMS
Recovery
  1. Display the status of controlled features in the system. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled but is not turned on.
  2. Enable the desired feature. Refer to the appropriate feature manual for assistance.
  3. Re-enter the dlt/rtrv-home-smsc command that generateed this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
