Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3894 Cmd Rej: SADDR and EADDR must have the same number of digits
The saddr and eaddr parameters must contain the same number of digits.
Recovery
  1. Display the current values for the saddr parameter if applicable. Enter the rtrv-gsmmap-scrn command.
  2. Re-enter the ent/rtrv-gsmmap-scrn command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - Features User's Guide for assistance.
