| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The value specified for the eaddr parameter must be greater than the value specified for the saddr parameter.
Recovery
saddr parameter, if applicable. Enter the rtrv-gsmmap-scrn command. ent/rtrv-gsmmap-scrn command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - Features User's Guide for assistance.
