Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Contents
Previous
Next
E3867 Cmd Rej: MPC feature must be enabled
The Multiple Point Code (MPC) feature must be turned on before a secondary point code can be added.
Once a feature that is controlled using a feature bit has been turned on, it cannot be turned off.
Recovery
Display the status of the MPC feature. Enter the
rtrv-feat
command.
Turn on the MPC feature as necessary. Refer to the
Database Administration - SS7 User's Guide
for assistance.
Re-enter the
ent/dlt/rtrv-spc
command that generated this error message.
Contact My Oracle Support if this error message appears again. See
My Oracle Support (MOS)
