| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
chg-stpopts command using these parameters. on=mfc - turns the MFC option on. When the MFC option is turned on, Message Flow Control controls the traffic in the EAGLE. Note:
When turning on MFC, the following cards are not supported from EAGLE Release 44.0 or later, except during migration to the B-series cards:Note:
A loss in MSU traffic may occur while running bi-directional traffic at 700 MSUs per second, 272 bytes on an E1-ATM or LIM-ATM card after GTT, while two STC cards are active.Note:
If anotherchg-stpopts:on=mfc or chg-stpopts:off=mfc command is issued within 10 seconds, the second command is rejected.
