| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to enable and activate these controlled features, Command Class Management, IP User Interface, and Network Security Enhancements, using the feature’s part number and a feature access key for each feature.
The feature access key is based on the feature’s part number and the serial number of the EAGLE, making the feature access key site-specific.
The
enable-ctrl-feat command enables the
controlled feature by inputting the controlled feature’s access key and the
controlled feature’s part number with these parameters:
:fak – The feature access key generated by the feature
access key generator. The feature access key contains 13 alphanumeric
characters and is not case sensitive.
:partnum – The
Oracle-issued part number associated with the controlled feature. The part
number is a 9-digit number, not including dashes. The first three digits must
be 893 (that is, 893xxxxxx, where x is a numeric value).
If the controlled feature is being enabled with a temporary feature access key, the feature must not be in the in-use, expired, or unavailable state.
The
enable-ctrl-feat command requires that
the database contain a valid serial number for the
EAGLE, and that this serial number is locked.
This can be verified with the
rtrv-serial-num command. The
EAGLE is shipped with a serial number in the
database, but the serial number is not locked. The serial number can be
changed, if necessary, and locked once the
EAGLE is on-site, with the
ent-serial-num command. The
ent-serial-num command uses these
parameters.
:serial – The serial number assigned to the EAGLE. The serial number is
not case sensitive.
:lock – Specifies whether
or not the serial number is locked. This parameter has only one value,
yes, which locks the serial number.
Once the serial number is locked, it cannot be changed.
To enter and lock the EAGLE’s serial number, theent-serial-num command must be entered
twice, once to add the correct serial number to the database with the
serial parameter, then again with the
serial and the
lock=yes parameters to lock the serial
number. You should verify that the serial number in the database is correct
before locking the serial number. The serial number can be found on a label
affixed to the control shelf (shelf 1100).
Once the controlled feature has been enabled, the
controlled feature must be activated with the
chg-ctrl-feat command. The
chg-ctrl-feat command uses these
parameters:
:partnum – The
:status=on – used to
activate the controlled features that customer has purchased and enabled.
The status of the controlled features in the
EAGLE is shown with the
rtrv-ctrl-feat command.
The part numbers for the Command Class Management, IP User Interface, and Network Security Enhancements features are:
Command Class Management – 893005801
Telnet (IP User Interface) – 893005701
Network Security Enhancements – 893009101
Figure A-1 Activating Controlled Features
Sheet 1 of 4
Sheet 2 of 4
Sheet 3 of 4
Sheet 4 of 4
