| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to enable and activate the EAGLE OAM IP Security Enhancement Controlled Feature, using the feature’s part number and a feature access key.
For Release 46.5 and later. the EAGLE OA&M IP Security feature is enabled by default and the feature entry is used to control only the alarming if the SSH for terminals or Security of FTP Server entries is OFF. SSH for terminals and Security of FTP Server entries are controlled via the SECU-DFLT: SSH parameter and SECUIRTY parameter against the FTP servers entries, respectively. The following is expected after upgrade to release 46.5 or later from release 46.4 or earlier:
With SSH for terminals ON, a secure shell connection is
established between the
EAGLE and the telnet terminals allowing
passwords to be sent over the connection. This allows the
EAGLE administrator to add new users to the
EAGLE (with the
ent-user command) and to change the
passwords of existing users (with the
pid parameter of the
chg-user command) from a telnet
terminal.
If the SSH for terminals is ON, the FTRA must be configured to support secure connections to the EAGLE. Go to FTP Table Base Retrieval User's Guide, for more information on using secure connections with the FTRA.
If Security of meas FTP Server entry is ON, the Measurements Platform must support secure FTP servers. Go to the Adding an FTP Server procedure for more information on configuring secure FTP servers for the Measurements Platform.
Similarly, if Security of FTP Server entry for any specific application (dist, db, user) is ON, the designated FTP server for the application must support secure FTP protocol.
Caution:
If EAGLE
OA&M
IP Security
Enhancements feature is activated with a temporary feature access key and that
key expires, secure shell connections will become non-secure. Passwords can be
transmitted on a non-secure connection, but cannot be assigned or changed. The
ent-user command and
chg-user command cannot be used. File
transfers using secure
FTP cannot be performed
unless non-secure
FTP servers are
available. It is recommended that the
FTRA and the Measurements
Platform is configured with secure and non-secure
FTP servers.
To enable and activate this feature, the
enable-ctrl-feat,
ent-serial-num, and
chg-ctrl-feat commands are used. For
more information on these commands, go to the
Activating Controlled Features
procedure, or
Commands User's Guide.
Figure A-2 Activating the EAGLE OA&M IP Security Enhancement Controlled Feature
Sheet 1 of 4
Sheet 2 of 4
Sheet 3 of 4
Sheet 4 of 4
