| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
SLIC cards are equipped with 16G bytes of RAM. They can run on either the 32-bit mode BLSLC32 flash GPL or on the 64-bit mode BLSLC64 flash GPL.
Follow the steps in SLIC 32-bit to 64-bit Conversion or SLIC 64-bit to 32-bit Conversion in order to convert a SLIC card to operate from one mode to the other.
