| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to remove an SS7 LIM (link interface module) from the database using the dlt-card command. The card cannot be removed if it does not exist in the database.
No SS7 signaling links can be assigned to the card you wish to remove from the database.
Caution:
If the SS7 LIM is the last SS7 LIM in service, removing this card from the database will cause SS7 traffic to be lost and isolate the EAGLE from the network.
1. LIM-E1 or LIMCH cards for E1 signaling links are removed from the database using the procedures in Appendix A, "E1 Interface" in Database Administration - SS7 User's Guide.
2. LIM-T1 or LIMCH cards for T1 signaling links are removed from the database using the procedures in Appendix B, "T1 Interface" in Database Administration - SS7 User's Guide.
3. IP cards (DCMs used for IP links) are removed from the database using the procedures in Database Administration - IP7 User's Guide.
The examples in this procedure are used to remove the SS7 LIMs in card location 1201, 1311, and 1318.
Canceling the REPT-STAT-CARD Command
Because the rept-stat-card command used in this procedure can output information for a long period of time, the rept-stat-card command can be canceled and the output to the terminal stopped. There are three ways that the rept-stat-card command can be canceled.
F9 function key on the keyboard at the terminal where the rept-stat-card command was entered.canc-cmd without the trm parameter at the terminal where the rept-stat-card command was entered.canc-cmd:trm=<xx>, where <xx> is the terminal where the rept-stat-card command was entered, from another terminal other that the terminal where the rept-stat-card command was entered. To enter the canc-cmd:trm=<xx> command, the terminal must allow Security Administration commands to be entered from it and the user must be allowed to enter Security Administration commands. The terminal’s permissions can be verified with the rtrv-secu-trm command. The user’s permissions can be verified with the rtrv-user or rtrv-secu-user commands.For more information about the canc-cmd command, go to Commands User's Guide.
Figure 4-16 Removing an SS7 LIM
Sheet 1 of 2
Sheet 2 of 2
