| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to configure the threshold (the number of times during a specified period of time) a specific UIM (unsolicited information message) is displayed at an EAGLE terminal using the set-uim-acthresh command.
The set-uim-acthresh command uses these parameters.
:uimn – The number of the UIM that the threshold is being created for, or the threshold being changed. The number of the UIM must exist in the EAGLE. See Unsolicited Alarm and Information Messages Reference for a list of the UIMs that can be displayed.
:limit – The number of UIMs that can be displayed in the amount of time specified by the intrvl parameter.
:intrvl – The amount of time, in minutes, that the number of UIMs specified by the limit parameter can be displayed at the EAGLE terminal.
:force – The force=yes parameter allows the limit parameter to be set to 0 should the conditions at the EAGLE make this action necessary. Setting the limit parameter to 0 prevents the specified UIM, and the information contained in the UIM, from being displayed at the EAGLE terminal. It is highly recommended that the limit parameter value is not set to 0.
When the limit=0 and the force=yes parameters are specified with the set-uim-acthresh command, this message appears in the scroll area of the terminal display.
Caution: Setting LIMIT=0 suppresses UIM permanently
When creating a new UIM threshold, both the limit and intrvl parameters must be specified with the set-uim-acthresh command.
If you are changing an existing UIM threshold, either the limit or intrvl parameters must be specified with the set-uim-acthresh command.
The examples used in this procedure change the time interval for the existing UIM threshold for UIM 1155 from 30 minutes to 20 minutes, the number of UIMs displayed for existing UIM threshold for UIM 1162 from 100 to 25, and to create a new UIM threshold to display UIM 1075 for 175 times in 30 minutes. These changes are shown in Table 4-5.
Table 4-5 Example UIM Threshold Configuration
| UIM Number | Old Limit | Old Time Interval | New Limit | New Time Interval |
| 1155 |
50 |
30 |
No Change |
20 |
| 1162 |
100 |
5 |
25 |
No Change |
| 1075 |
N/A |
N/A |
175 |
30 |
Figure 4-17 Configuring the UIM Threshold
