| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
High-capacity cards that were issued before EAGLE Release 43.0 may not be loaded with the BLIXP GPL. This procedure updates the high-capacity card with the BLIXP GPL using the flash-card command. The BLIXP GPL is a tar image of all the flash GPLs that are necessary to operate the high-capacity cards. The high-capacity cards are shown in Table 3-7. When the BLIXP GPL is downloaded to the card, the tar image is un-archived and the flash GPLs are loaded onto the card.
Table 3-7 High-Capacity Cards
| HC MIM | E5-E1T1 | E5-ENET |
| E5-STC | E5-SLAN | E5-SM4G |
| E5-ATM | E5-TSM |
Caution:
Theflash-card command cannot be entered if the IMT Rate Change sequence or the Extended Bit Error Rate Test (BERT) is being performed.The applications and entities supported by the high-capacity cards are shown in Table 3-8.
Table 3-8 High-Capacity Card Applications
| High-Capacity Card | Card Name (as shown on the card label) | Application | Application GPL Running on the Card | Supported Entities |
| HC MIM | HC MIM | SS7ANSI, CCS71TU | SS7HC | E1 or T1 signaling links |
| E5-E1T1 | E5-E1T1 | SS7ANSI, CCS71TU | SS7HC | E1 or T1 signaling links |
| E5-ENET | E5-ENET | SS7IPGW, IPLIM, IPLIMI, IPGWI, IPSG | IPLHC, IPGHC, IPSG | IP signaling links |
| E5-STC | E5-ENET | EROUTE | ERTHC | EAGLE 5 Integrated Monitoring Support |
| E5-SM4G | E5-SM4G | VSCCP | SCCPHC | GTT-related features |
| E5-SLAN | E5-ENET | STPLAN | SLANHC | TCP/IP data links for the STPLAN feature |
| E5-ENET-B/SLIC | E5-ENET-B SLIC |
IPS | IPSHC | Telnet sessions for remote connections to the EAGLE and SEAS terminals for the SEAS over IP feature |
| E5-ATM | E5-ATM | ATMANSI, ATMITU | ATMHC | ANSI and ITU ATM high-speed signaling links |
| E5-TSM | E5-TSM | GLS | GLSHC | Gateway Screening related features |
Caution:
Before any high-capacity card can be updated with the BLIXP GPL, all the traffic hosted by the high-capacity card must be stopped, and the high-capacity card must be taken out of service.Canceling the REPT-STAT-SLK and RTRV-SLK Commands
Because the rept-stat-slk and rtrv-slk commands used in this procedure can output information for a long period of time, the rept-stat-slk and rtrv-slk commands can be canceled and the output to the terminal stopped. There are three ways that the rept-stat-slk and rtrv-slk commands can be canceled.
F9 function key on the keyboard at the terminal where the rept-stat-slk or rtrv-slk commands command were entered. canc-cmd without the trm parameter at the terminal where the rept-stat-slk or rtrv-slk commands were entered. canc-cmd:trm=<xx>, where <xx> is the terminal where the rept-stat-slk or rtrv-slk commands were entered, from another terminal other that the terminal where the rept-stat-slk or rtrv-slk commands were entered. To enter the canc-cmd:trm=<xx> command, the terminal must allow Security Administration commands to be entered from it and the user must be allowed to enter Security Administration commands. The terminal’s permissions can be verified with the rtrv-secu-trm command. The user’s permissions can be verified with the rtrv-user or rtrv-secu-user commands. For more information about the canc-cmd command, go to Commands User's Guide.
rtrv-gpl:gpl=blixp
If E5-based control cards are installed in the EAGLE, this is an example of the possible output.
rlghncxa03w 10-12-01 11:34:04 GMT EAGLE5 43.0.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL BLIXP 1114 133-003-000 133-003-000 133-002-000 133-003-000 BLIXP 1116 133-003-000 133-003-000 133-002-000 133-003-000 BLIXP 1115 ----------- ----------- ----------- -----------
rept-stat-card command and specifying the location of the card. For this example, enter this command.
rept-stat-card:loc=1303
For an HC MIM or E5-E1T1 card, this is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0
CARD VERSION TYPE GPL PST SST AST
1303 133-003-000 LIME1 SS7HC IS-NR Active -----
ALARM STATUS = No Alarms.
IMTPCI GPL version = 133-002-000
BLCPLD GPL version = 133-002-000
BLDIAG6 GPL version = 133-002-000
BLBIOS GPL version = 133-002-000
BLVXW6 GPL version = 133-002-000
BLROM1 GPL version = 133-002-000
PLDPMC1 GPL version = 133-002-000
IMT BUS A = Conn
IMT BUS B = Conn
SIGNALING LINK STATUS
SLK PST LS CLLI
A IS-NR e11303a -----------
B IS-NR e11303b -----------
A1 IS-NR e11303a -----------
B3 IS-NR e11303b -----------
Command Completed.
For an E5-E1T1 card, this is an example of the possible output.
1303 133-003-000 LIME1 SS7EPM IS-NR Active -----
BLBEPM GPL version = 133-002-000
IMT BUS A = Conn
IMT BUS B = Conn
CURRENT TEMPERATURE = 32C ( 90F) [ALARM TEMP: 60C (140F)]
PEAK TEMPERATURE: = 39C (103F) [06-05-02 13:40]
SLK PST LS CLLI
Command Completed.
For an E5-ENET card, this is an example of the possible output.
1303 133-003-000 DCM IPLHC IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
Command Completed.
For an E5-STC card, this is an example of the possible output.
1303 133-003-000 STC ERTHC IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
CURRENT TEMPERATURE = 61C (142F)
PEAK TEMPERATURE: = 61C (142F) [00-02-14 10:33]
EROUTE % OCCUP = 0%
NTP broadcast = VALID
STC IP PORT A: OOS-MT Unavail -----
ALARM STATUS = ** 0084 IP Connection Unavailable
ERROR STATUS = DHCP Lease. Physical Link.
STC IP PORT B: OOS-MT Unavail -----
Command Completed.
For an E5-SLAN card, this is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 133-003-000 DCM SLANHC IS-NR Active ----- ALARM STATUS = No Alarms. IMTPCI GPL version = 133-002-000 BLVXW6 GPL version = 133-002-000 BLDIAG6 GPL version = 133-002-000 BLBEPM GPL version = 133-002-000 BLCPLD GPL version = 133-002-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 60C (140F) PEAK TEMPERATURE: = 63C (146F) [00-02-12 21:58] DLK A PST = IS-NR SST = Avail AST = ----- SLAN % EAGLE CAPACITY = 57% SLAN % HOST CAPACITY = 49% Command Completed.
For an E5-SM4G card, this is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 133-003-000 DSM SCCPHC IS-NR Active ----- ALARM STATUS = No Alarms. IMTPCI GPL version = 133-002-000 BLVXW6 GPL version = 133-002-000 BLDIAG6 GPL version = 133-002-000 BLBSMG GPL version = 133-002-000 BLCPLD GPL version = 133-002-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 31C ( 88F) PEAK TEMPERATURE: = 32C ( 90F) [07-05-12 15:55] SCCP % OCCUP = 1% Command Completed.
For an E5-ENET-B/SLIC card, this is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 133-003-000 IPSM IPSHC IS-NR Active ----- ALARM STATUS = No Alarms. IMTPCI GPL version = 133-002-000 BLVXW6 GPL version = 133-002-000 BLDIAG6 GPL version = 133-002-000 BLBEPM GPL version = 133-002-000 BLCPLD GPL version = 133-002-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 32C ( 90F) PEAK TEMPERATURE: = 39C (103F) [06-05-02 13:40] Command Completed.
For an E5-ATM card, this is an example of the possible output.
1303 133-003-000 LIMATM ATMHC IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
CURRENT TEMPERATURE = 38C (101F)
PEAK TEMPERATURE: = 38C (101F) [07-11-23 06:10]
SLK PST LS CLLI
A IS-NR ls1 -----------
Command Completed.
For an E5-TSM card, this is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 133-003-000 TSM GLSHC IS-NR Active ----- ALARM STATUS = No Alarms. IMTPCI GPL version = 133-002-000 BLVXW6 GPL version = 133-002-000 BLDIAG6 GPL version = 133-002-000 BLBEPM GPL version = 133-002-000 BLCPLD GPL version = 133-002-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 38C (101F) PEAK TEMPERATURE: = 38C (101F) [07-11-23 06:10] Command Completed.
Continue the procedure by performing one of these actions:
GPL column in the rept-stat-card output in 2), continue the procedure with 5. GPL column in the rept-stat-card output in 2), continue the procedure with 12. GPL column in the rept-stat-card output in 2), continue the procedure with 7. GPL column in the rept-stat-card output in 2), continue the procedure with 9. GPL column in the rept-stat-card output in 2), continue the procedure with 4. GPL column in the rept-stat-card output in 2), continue the procedure with 3. rept-stat-card:appl=gls
The output from this command will display the TSMs that are running the GLS GPL and the E5-TSMs that are running the GLSHC GPL.
This is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1207 133-003-000 TSM GLSHC IS-NR Active ----- 1211 133-003-000 TSM GLSHC IS-NR Active ----- 1303 133-003-000 TSM GLSHC IS-NR Active ----- Command Completed.
Continue the procedure with 12.
rept-stat-sccp command.The output from this command will display the DSMs that are running the VSCCP GPL and the E5-SM4G cards that are running the SCCPHC GPL.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION PST SST AST MSU USAGE CPU USAGE ----------------------------------------------------------------------------- 1303 133-003-000 IS-NR Active ----- 47% 81% 2103 133-003-000 IS-NR Active ----- 34% 50% 2111 133-003-000 IS-NR Active ----- 21% 29% 2115 133-003-000 IS-NR Active ----- 35% 52% 2117 133-003-000 IS-NR Active ----- 40% 71% ----------------------------------------------------------------------------- SCCP Service Average MSU Capacity = 36% Average CPU Capacity = 56% Command Completed.
Therept-stat-sccp command output contains other fields that are not used by this procedure. If you wish to see all the fields displayed by the rept-stat-sccp command, refer to the rept-stat-sccp command description in Commands User's Guide.Continue the procedure with 12.
Enter the rtrv-slk command with the card location specified in 2. For this example, enter this command.
rtrv-slk:loc=1303
This is an example of the possible output for an HC MIM or E5-E1T1 card.
L2T PCR PCR E1 E1
LOC LINK LSN SLC TYPE SET BPS ECM N1 N2 LOC PORT TS
1303 A e11303a 0 LIME1 1 64000 PCR 76 3800 1303 2 12
1303 B e11303b 0 LIME1 1 56000 BASIC --- ----- 1303 1 2
1303 A1 e11303a 1 LIME1 1 56000 BASIC --- ----- 1303 1 3
1303 B3 e11303b 1 LIME1 1 56000 BASIC --- ----- 1303 1 7
This is an example of the possible output for an E5-ENET card.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 LOC LINK LSN SLC TYPE IPLIML2 1303 A e11303a 0 IPLIM M2PA 1303 B e11303b 0 IPLIM M2PA 1303 A1 e11303a 1 IPLIM M2PA 1303 B3 e11303b 1 IPLIM M2PA
This is an example of the possible output for an E5-ATM card.
LP ATM
LOC LINK LSN SLC TYPE SET BPS TSEL VCI VPI LL
1303 A ls2 2 LIMATM 1 1544000 LINE 5 0 0
1303 B ls1 3 LIMATM 1 1544000 LINE 5 0 0
dact-slk command. For this example, enter these commands.
dact-slk:loc=1303:link=a
dact-slk:loc=1303:link=b
dact-slk:loc=1303:link=a1
dact-slk:loc=1303:link=b3
Caution:
These command examples place the signaling links on card 1303 out of service. This will interrupt service on the signaling links on card 1303 and allow the BLIXP GPL to be loaded on to card 1303.Caution:
If the EAGLE contains only signaling links assigned to the card that is specified in this step, deactivating all of the signaling links that are assigned to the card will take all of these signaling links out of service and will isolate the EAGLE from the network.When each of these commands have successfully completed, this message should appear.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Deactivate SLK message sent to card
rept-stat-dlk command with the card location specified in 2. For this example, enter this command.
rept-stat-dlk:loc=1303This is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 DLK PST SST AST 1303 IS-NR Active ---- Alarm Status = No Alarms. Command Completed.
canc-dlk command. For this example, enter this command. canc-dlk:loc=1303
Caution:
This command example places the TCP/IP data link on card 1303 out of service. This will interrupt service on the TCP//IP data link on card 1303 and allow the flash GPL to be loaded onto card 1303.Caution:
If there is only one TCP/IP data link in the EAGLE, placing the card out of service will cause the STPLAN feature to be disabled.When this command has successfully completed, these messages should appear.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Deactivate Link message sent to card. Command Completed.
rtrv-trm command. The Telnet terminals associated with the card shown in 9 must be taken out of service. The Telnet terminals are shown in the output with the entry TELNET in the TYPE field. This is an example of the possible output. In this example, the Telnet terminals that must be taken out of service are terminals 17 to 24.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 TRM TYPE COMM FC TMOUT MXINV DURAL 1 VT320 9600-7-E-1 SW 30 5 99:59:59 2 KSR 9600-7-E-1 HW 30 5 INDEF 3 PRINTER 4800-7-E-1 HW 30 0 00:00:00 4 VT320 2400-7-E-1 BOTH 30 5 00:30:00 5 VT320 9600-7-O-1 NONE 30 5 00:00:30 6 VT320 9600-7-O-1 NONE 30 5 00:00:30 7 PRINTER 9600-7-E–2 HW 30 5 00:30:00 8 KSR 19200-7-E-2 BOTH 30 5 00:30:00 9 VT320 9600-7-O-1 NONE 30 5 00:00:30 10 VT320 9600-7-E-1 HW 30 5 00:30:00 11 VT320 4800-7-E-1 HW 30 5 00:30:00 12 PRINTER 9600-7-E-1 HW 30 4 00:30:00 13 VT320 9600-7-O-1 NONE 30 5 00:30:00 14 VT320 9600-7-E-2 SW 30 8 00:30:00 15 VT320 9600-7-E–2 HW 30 5 00:30:00 16 VT320 9600-7-E-2 BOTH 30 3 00:30:00 TRM TYPE LOC TMOUT MXINV DURAL 17 TELNET 1303 60 5 00:30:00 18 TELNET 1303 60 5 00:30:00 19 TELNET 1303 60 5 00:30:00 20 TELNET 1303 60 5 00:30:00 21 TELNET 1303 60 5 00:30:00 22 TELNET 1303 60 5 00:30:00 23 TELNET 1303 60 5 00:30:00 24 TELNET 1303 60 5 00:30:00 25 TELNET 1203 60 5 00:30:00 26 TELNET 1203 60 5 00:30:00 27 TELNET 1203 60 5 00:30:00 28 TELNET 1203 60 5 00:30:00 39 TELNET 1203 60 5 00:30:00 30 TELNET 1203 60 5 00:30:00 31 TELNET 1203 60 5 00:30:00 32 TELNET 1203 60 5 00:30:00 33 TELNET 1208 60 5 00:30:00 34 TELNET 1208 60 5 00:30:00 35 TELNET 1208 60 5 00:30:00 36 TELNET 1208 60 5 00:30:00 37 TELNET 1208 60 5 00:30:00 38 TELNET 1208 60 5 00:30:00 39 TELNET 1208 60 5 00:30:00 40 TELNET 1208 60 5 00:30:00
Thertrv-trm command output contains other fields that are not used by this procedure. If you wish to see all the fields displayed by the rtrv-trm command, see the rtrv-trm command description in Commands User's Guide. rept-stat-trm command. This is an example of the possible output. rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 TRM PST SST AST 1 IS-NR Active ----- 2 IS-NR Active ----- 3 IS-NR Active ----- 4 IS-NR Active ----- 5 IS-NR Active ----- 6 IS-NR Active ----- 7 IS-NR Active ----- 8 IS-NR Active ----- 9 IS-NR Active ----- 10 IS-NR Active ----- 11 IS-NR Active ----- 12 IS-NR Active ----- 13 IS-NR Active ----- 14 IS-NR Active ----- 15 IS-NR Active ----- 16 IS-NR Active ----- 17 IS-NR Active ----- 18 IS-NR Active ----- 19 IS-NR Active ----- 20 IS-NR Active ----- 21 IS-NR Active ----- 22 IS-NR Active ----- 23 IS-NR Active ----- 24 IS-NR Active ----- 25 IS-NR Active ----- 26 IS-NR Active ----- 27 IS-NR Active ----- 28 IS-NR Active ----- 29 IS-NR Active ----- 30 IS-NR Active ----- 31 IS-NR Active ----- 32 IS-NR Active ----- 33 IS-NR Active ----- 34 IS-NR Active ----- 35 IS-NR Active ----- 36 IS-NR Active ----- 37 IS-NR Active ----- 38 IS-NR Active ----- 39 IS-NR Active ----- 40 IS-NR Active ----- Command Completed.
rmv-trm or the inh-trm command. The function of the rmv-trm and the inh-trm commands are the same. For this example, enter these commands. rmv-trm:trm=17
rmv-trm:trm=18
rmv-trm:trm=19
rmv-trm:trm=20
rmv-trm:trm=21
rmv-trm:trm=22
rmv-trm:trm=23
rmv-trm:trm=24
If the terminal that is being taken out of service is the last in service SEAS terminal, theforce=yes parameter must be specified with thermv-trm command for that terminal. Caution:
Placing the Telnet terminals out of service will disable any Telnet sessions running on these terminals.If the status of any of the terminals shown in the PST field in 10 is OOS-MT-DSBLD (out-of-service maintenance disabled), the terminal is already out of service and the rmv-trm command does not need to be executed for that terminal.
This message should appear when each of these commands have successfully completed.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Inhibit message sent to terminal rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Command Completed.
rmv-card or inh-card command. The function of the rmv-card and the inh-card commands are the same.For this example, enter this command.
rmv-card:loc=1303
When this command has successfully completed, this message should appear.
rlghncxa03w 10-12-01 11:11:28 GMT EAGLE5 43.0.0 Card has been inhibited.
force=yes parameter must be specified in this step if any of these conditions exist.flash-card command with the code=appr and the card location parameters. Caution:
Theflash-card command cannot be entered if the IMT Rate Change sequence or the Extended Bit Error Rate Test (BERT) is being performed. For this example, enter this command.
flash-card:code=appr:loc=1303
Flash Card: Downloading BLIXP on card 1303.
Flash Card: Card 1303 download BLIXP complete.
Flash Card: Activating BLIXP on card 1113.
Flash Card: Card 1303 activation BLIXP complete.
rrlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0
Command Completed.
rst-card or alw-card command. The function of the rst-card and the alw-card commands are the same.The rst-card or alw-card command also loads the approved version of the BLIXP GPL onto the card.
rst-card:code=appr:loc=1303
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Card has been allowed.
rept-stat-card command. For this example, enter this command.
BLIXP GPL version = 133-003-000
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
A OOS-MT-DSBLD e11303a -----------
B OOS-MT-DSBLD e11303b -----------
A1 OOS-MT-DSBLD e11303a -----------
B3 OOS-MT-DSBLD e11303b -----------
Command Completed.
1303 133-003-000 IPLIM SS7EPM IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
Command Completed.
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
Command Completed.
IMT BUS A = Conn
IMT BUS B = Conn
PEAK TEMPERATURE: = 61C (142F) [06-05-02 13:40]
Command Completed.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 133-003-000 DCM SLANHC IS-NR Active ----- ALARM STATUS = No Alarms. BLIXP GPL version = 133-003-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 60C (140F) PEAK TEMPERATURE: = 63C (146F) [00-02-12 21:58] DLK A PST = IS-NR SST = Avail AST = ----- SLAN % EAGLE CAPACITY = 57% SLAN % HOST CAPACITY = 49% Command Completed.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 133-003-000 DSM SCCPHC IS-NR Active ----- ALARM STATUS = No Alarms. BLIXP GPL version = 133-003-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 31C ( 88F) PEAK TEMPERATURE: = 32C ( 90F) [07-05-12 15:55] SCCP % OCCUP = 1% Command Completed.
For an E5-ENET-B or SLIC card, this is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 133-003-000 IPSM IPSHC IS-NR Active ----- ALARM STATUS = No Alarms. BLIXP GPL version = 133-003-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 32C ( 90F) PEAK TEMPERATURE: = 39C (103F) [06-05-02 13:40] Command Completed.
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
Command Completed.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 133-003-000 TSM GLSHC IS-NR Active ----- ALARM STATUS = No Alarms. BLIXP GPL version = 133-003-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 38C (101F) PEAK TEMPERATURE: = 38C (101F) [07-11-23 06:10] Command Completed.
If the version number of the BLIXP GPL that is shown in this step is not the version specified in 1, contact the Customer Care Center. Refer to the My Oracle Support (MOS) section for the contact information.Continue the procedure by performing one of these actions.
GPL column in the rept-stat-card output in 15), continue the procedure with 16. GPL column in the rept-stat-card output in 15), continue the procedure with 22. GPL column in the rept-stat-card output in 15), continue the procedure with 18. GPL column in the rept-stat-card output in 15), continue the procedure with 20. act-slk command. For this example, enter these commands.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Activate SLK message sent to card
rept-stat-slk command with the card location and signaling link. For this example, enter these commands.
rept-stat-slk:loc=1303:link=a
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 SLK LSN CLLI PST SST AST 1303,A e11303a ----------- IS-NR Avail ---- ALARM STATUS = No Alarms. UNAVAIL REASON = --
rept-stat-slk:loc=1303:link=b
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 SLK LSN CLLI PST SST AST 1303,B e11303b ----------- IS-NR Avail ---- ALARM STATUS = No Alarms. UNAVAIL REASON = --
rept-stat-slk:loc=1303:link=a1
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 SLK LSN CLLI PST SST AST 1303,A1 e11303a ----------- IS-NR Avail ---- ALARM STATUS = No Alarms. UNAVAIL REASON = --
rept-stat-slk:loc=1303:link=b3
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 SLK LSN CLLI PST SST AST 1303,B3 e11303b ----------- IS-NR Avail ---- ALARM STATUS = No Alarms. UNAVAIL REASON = -- Command Completed.
Continue the procedure with 22.
act-dlk command. For this example, enter this command. act-dlk:loc=1303 rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Activate Link message sent to card.
rept-stat-dlk command. For this example, enter this command. rept-stat-dlk:loc=1303This is an example of the possible output.
rst-trm or alw-trm command. The function of the rst-trm and the alw-trm commands are the save. For this example, enter these commands. rst-trm:trm=17 rst-trm:trm=18 rst-trm:trm=19 rst-trm:trm=20 rst-trm:trm=21 rst-trm:trm=22 rst-trm:trm=23 rst-trm:trm=24 This message should appear when each of these commands have successfully completed.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Allow message sent to terminal rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Command Completed.
Figure 3-9 Updating a High-Capacity Card to Run the BLIXP GPL
Sheet 1 of 4
Sheet 2 of 4
Sheet 3 of 4
Sheet 4 of 4
