This procedure is used to activate the fan using the chg-feat command with this parameter.
fan=on - turns the fan on. When the fan is turned on, system cards and functions that generate heat in the EAGLE can function properly.
Enter the rtrv-feat command to check the status of the Fan feature.
The rtrv-feat command output contains other fields that are not used by this procedure. If you wish to see all the fields displayed by the rtrv-feat command, see the rtrv-feat command description in Commands User's Guide.
If the fan feature is not on, use the chg-feat:fan=on command to turn on the fan.
