| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to remove a Measurement Collection & Polling Module (MCPM) from the database using the dlt-card command.
Caution:
If the MCPM is the last MCPM in service, removing this card from the database will disable the Measurements Platform feature.The examples in this procedure are used to remove the MCPM in card location 2107.
Canceling the REPT-STAT-CARD Command
Because the rept-stat-card command used in this procedure can output information for a long period of time, the rept-stat-card command can be canceled and the output to the terminal stopped. There are three ways that the rept-stat-card command can be canceled.
Press the F9 function key on the keyboard at the terminal where the rept-stat-card command was entered.
Enter the canc-cmd without the trm parameter at the terminal where the rept-stat-card command was entered.
Enter the canc-cmd:trm=<xx>, where <xx> is the terminal where the rept-stat-card command was entered, from another terminal other that the terminal where the rept-stat-card command was entered. To enter the canc-cmd:trm=<xx> command, the terminal must allow Security Administration commands to be entered from it and the user must be allowed to enter Security Administration commands. The terminal’s permissions can be verified with the rtrv-secu-trm command. The user’s permissions can be verified with the rtrv-user or rtrv-secu-user commands.
For more information about the canc-cmd command, go to Commands User's Guide.
Figure 4-21 Removing a MCPM
