| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to configure SEAS terminals for the SEAS over IP feature. The SEAS terminal can be configured only on E5-IPSMs.
As of Release 46.5, the E5-IPSM card and its functionality is replaced by the E5-ENET-B (p/n 870-2971-01) or SLIC (p/n 7094646) card. Any references to E5-IPSM and the 870-2877-01 part number should be replaced by the 46.5 and greater card and part number.The EAGLE can contain a maximum of two SEAS terminals, but only one SEAS terminal can be configured on an E5-IPSM. When an E5-IPSM is configured in the database, eight telnet terminals are created. To configure the SEAS terminal, one of these telnet terminals is changed to a SEAS terminal using the chg-trm command with these parameters.
:trm – The number of the telnet terminal being changed, 17 through 40
:type=seas – The SEAS terminal type.
The chg-trm command contains other parameters, but these parameters cannot be used in this procedure. For more information on these parameters, see the Changing Terminal Characteristics procedure in this manual, or the chg-trm command description in Commands User's Guide.
SEAS terminals can be configured only if the SEAS over IP feature is enabled. The status of the SEAS over IP feature is shown in the rtrv-ctrl-feat output. If the SEAS over IP feature is not enabled, perform the Activating the SEAS over IP Feature procedure in this chapter to enable the SEAS over IP feature.
When the SEAS terminal is configured, the value for the SEAS output group parameter is set to YES. The values for the other output group parameters and the tmout, dural, and mxinv parameters are not changed.
The other output group parameters can be changed with the specific output group parameter or the all parameter. If the all=no parameter is specified for a SEAS terminal (type=seas), all the output group values are changed to NO except for the SEAS output group. The SEAS output group value remains set to YES and this message is displayed.
SEAS Output Group is SET for SEAS terminal <terminal number>
rtrv-ctrl-feat:partnum=893018801
This is an example of the possible output.
rlghncxa03w 07-05-28 21:15:37 GMT EAGLE5 37.0.0 The following features have been permanently enabled: Feature Name Partnum Status Quantity SEAS over IP 893018801 off ---- The following features have been temporarily enabled: Feature Name Partnum Status Quantity Trial Period Left Zero entries found. The following features have expired temporary keys: Feature Name Partnum Zero entries found.
If the SEAS over IP feature is enabled, go to step 2.
If the SEAS over IP feature is not enabled, perform the Activating the SEAS over IP Feature procedure in this chapter to enable SEAS over IP feature. After the SEAS over IP feature has been enabled, perform the Performing the Initial SEAS Configuration procedure in this chapter. After the Performing the Initial SEAS Configuration procedure has been performed, go to step 2.
rtrv-trm command. This is an example of the possible output.
rlghncxa03w 06-10-01 16:02:08 GMT EAGLE5 39.0.0
TRM TYPE COMM FC TMOUT MXINV DURAL
1 VT320 9600-7-E-1 SW 30 5 99:59:59
2 KSR 9600-7-E-1 HW 30 5 INDEF
3 PRINTER 4800-7-E-1 HW 30 0 00:00:00
4 VT320 2400-7-E-1 BOTH 30 5 00:30:00
5 VT320 9600-7-O-1 NONE 30 5 00:00:30
6 VT320 9600-7-E-2 SW 30 9 INDEF
7 PRINTER 9600-7-N-2 HW 30 5 00:30:00
8 KSR 19200-7-E-2 BOTH 30 5 00:30:00
9 VT320 9600-7-E-1 SW 30 7 00:30:00
10 VT320 9600-7-E-1 HW 30 5 00:30:00
11 VT320 4800-7-E-1 HW 30 5 00:30:00
12 PRINTER 9600-7-E-1 HW 30 4 00:30:00
13 VT320 9600-7-O-1 NONE 30 5 00:30:00
14 VT320 9600-7-E-2 SW 30 8 00:30:00
15 VT320 9600-7-N-2 HW 30 5 00:30:00
16 VT320 9600-7-E-2 BOTH 30 3 00:30:00
TRM TYPE LOC TMOUT MXINV DURAL SECURE
17 TELNET 1201 60 5 00:30:00 yes
18 TELNET 1201 60 5 00:30:00 yes
19 TELNET 1201 60 5 00:30:00 yes
20 TELNET 1201 60 5 00:30:00 yes
21 TELNET 1201 60 5 00:30:00 yes
22 TELNET 1201 60 5 00:30:00 yes
23 TELNET 1201 60 5 00:30:00 yes
24 TELNET 1201 60 5 00:30:00 yes
25 TELNET 1203 60 5 00:30:00 yes
26 TELNET 1203 60 5 00:30:00 yes
27 TELNET 1203 60 5 00:30:00 yes
28 TELNET 1203 60 5 00:30:00 yes
29 TELNET 1203 60 5 00:30:00 yes
30 TELNET 1203 60 5 00:30:00 yes
31 TELNET 1203 60 5 00:30:00 yes
32 TELNET 1203 60 5 00:30:00 yes
33 TELNET 1205 60 5 00:30:00 yes
34 TELNET 1205 60 5 00:30:00 yes
35 TELNET 1205 60 5 00:30:00 yes
36 TELNET 1205 60 5 00:30:00 yes
37 TELNET 1205 60 5 00:30:00 yes
38 TELNET 1205 60 5 00:30:00 yes
39 TELNET 1205 60 5 00:30:00 yes
40 TELNET 1205 60 5 00:30:00 yes
TRM LOGINTMR LOGOUTTMR PNGTIMEINT PNGFAILCNT
(sec) (sec) (msec)
17 none none none 1
18 none none none 1
19 none none none 1
20 none none none 1
21 none none none 1
22 none none none 1
23 none none none 1
24 none none none 1
25 none none none 1
26 none none none 1
27 none none none 1
28 none none none 1
28 none none none 1
30 none none none 1
31 none none none 1
32 none none none 1
33 none none none 1
34 none none none 1
35 none none none 1
36 none none none 1
37 none none none 1
38 none none none 1
39 none none none 1
40 none none none 1
TRM TRAF LINK SA SYS PU DB UIMRD
1 NO YES NO YES NO YES YES
2 NO NO NO NO NO NO NO
3 YES YES YES NO YES YES YES
4 YES NO NO NO NO NO NO
5 NO YES NO NO NO NO YES
6 NO NO YES NO NO NO NO
7 YES YES YES YES YES YES YES
8 NO NO NO NO YES NO YES
9 NO YES NO NO NO YES NO
10 NO NO NO NO NO NO YES
11 YES YES YES YES YES YES YES
12 YES YES YES YES YES YES YES
13 NO YES NO NO NO NO YES
14 NO NO YES NO NO NO NO
15 YES YES YES NO YES YES YES
16 NO NO NO NO YES NO YES
17 NO NO NO NO NO NO NO
18 NO NO NO NO NO NO NO
19 NO NO NO NO NO NO NO
20 NO NO NO NO NO NO NO
21 NO NO NO NO NO NO NO
22 NO NO NO NO NO NO NO
23 NO NO NO NO NO NO NO
24 NO NO NO NO NO NO NO
25 NO NO NO NO YES NO YES
26 NO NO NO NO NO NO NO
27 NO NO NO NO NO NO NO
28 NO NO NO NO NO NO NO
29 NO NO NO NO NO NO NO
30 NO NO NO NO NO NO NO
31 NO NO NO NO NO NO NO
32 NO NO NO NO NO NO NO
33 NO NO NO NO NO NO NO
34 NO NO NO NO YES NO YES
35 NO NO NO NO NO NO NO
36 NO NO NO NO NO NO NO
37 NO NO NO NO NO NO NO
38 NO NO NO NO NO NO NO
39 NO NO NO NO NO NO NO
40 NO NO NO NO NO NO NO
APP APP
TRM SERV SS CARD CLK DBG GTT GWS MEAS MON MPS SEAS SLAN
1 YES YES YES YES YES YES YES YES YES YES NO NO
2 YES YES YES YES YES YES YES YES YES YES NO NO
3 YES YES YES YES YES YES YES YES YES YES NO NO
4 YES YES YES YES YES NO YES YES YES YES NO NO
5 YES YES YES YES YES YES YES YES YES YES NO NO
6 YES YES YES YES YES YES YES YES YES YES NO NO
7 NO YES YES YES YES YES YES YES YES YES NO NO
8 YES YES YES YES YES YES YES YES YES YES YES YES
9 YES YES YES YES YES YES YES YES YES YES YES YES
10 NO NO NO NO NO NO NO NO NO NO NO NO
11 NO NO NO NO NO NO NO NO NO NO NO NO
12 NO NO NO NO NO NO NO NO NO NO NO NO
13 NO NO NO NO NO NO NO NO NO NO NO NO
14 NO NO NO NO NO NO NO NO NO NO NO NO
15 NO NO NO NO NO NO NO NO NO NO NO NO
16 NO NO NO NO NO NO NO NO NO NO NO NO
17 NO NO NO NO NO NO NO NO NO NO NO NO
18 NO NO NO NO NO NO NO NO NO NO NO NO
19 NO NO NO NO NO NO NO NO NO NO NO NO
20 NO NO NO NO NO NO NO NO NO NO NO NO
21 NO NO NO NO NO NO NO NO NO NO NO NO
22 NO NO NO NO NO NO NO NO NO NO NO NO
23 NO NO NO NO NO NO NO NO NO NO NO NO
24 NO NO NO NO NO NO NO NO NO NO NO NO
25 NO NO NO NO NO NO NO NO NO NO NO NO
26 NO NO NO NO NO NO NO NO NO NO NO NO
27 NO NO NO NO NO NO NO NO NO NO NO NO
28 NO NO NO NO NO NO NO NO NO NO NO NO
29 NO NO NO NO NO NO NO NO NO NO NO NO
30 NO NO NO NO NO NO NO NO NO NO NO NO
31 NO NO NO NO NO NO NO NO NO NO NO NO
32 NO NO NO NO NO NO NO NO NO NO NO NO
33 NO NO NO NO NO NO NO NO NO NO NO NO
34 NO NO NO NO NO NO NO NO NO NO NO NO
35 NO NO NO NO NO NO NO NO NO NO NO NO
36 NO NO NO NO NO NO NO NO NO NO NO NO
37 NO NO NO NO NO NO NO NO NO NO NO NO
38 NO NO NO NO NO NO NO NO NO NO NO NO
39 NO NO NO NO NO NO NO NO NO NO NO NO
40 NO NO NO NO NO NO NO NO NO NO NO NO
If no telnet terminals are shown in the rtrv-trm output, or only one telnet terminal is shown in the rtrv-trm output, perform the Adding an E5-IPSM procedure and add E5-IPSM cards to the database. A minimum of two E5-IPSMs are required. After the E5-IPSMs have been added to the database, skip step 3 and go to step 4.
If two or three telnet terminals are shown in the rtrv-trm output, go to step 3.
rtrv-trm output in step 2 are E5-IPSMs. Enter the rept-stat-card command specifying the card location shown in the rtrv-trm output in step 2. For this example, enter these commands. rept-stat-card:loc=1201
rlghncxa03w 06-10-01 09:12:36 GMT EAGLE5 36.0.0 CARD VERSION TYPE GPL PST SST AST 1201 126-003-000 IPSM IPSHC IS-NR Active ----- ALARM STATUS = No Alarms. IMTPCI GPL version = 126-002-000 BLVXW6 GPL version = 126-002-000 BLDIAG6 GPL version = 126-002-000 BLBEPM GPL version = 126-002-000 BLCPLD GPL version = 126-002-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 32C ( 90F) PEAK TEMPERATURE: = 39C (103F) [06-05-02 13:40] Command Completed.
rept-stat-card:loc=1203
rlghncxa03w 06-10-01 09:12:36 GMT EAGLE5 36.0.0 CARD VERSION TYPE GPL PST SST AST 1203 126-003-000 IPSM IPS IS-NR Active ----- ALARM STATUS = No Alarms. IMTPCI GPL version = 126-002-000 BLVXW6 GPL version = 126-002-000 BLDIAG6 GPL version = 126-002-000 BLBEPM GPL version = 126-002-000 BLCPLD GPL version = 126-002-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 32C ( 90F) PEAK TEMPERATURE: = 39C (103F) [06-05-02 13:40] Command Completed.
rept-stat-card:loc=1205
rlghncxa03w 06-10-01 09:12:36 GMT EAGLE5 36.0.0 CARD VERSION TYPE GPL PST SST AST 1205 126-003-000 IPSM IPS IS-NR Active ----- ALARM STATUS = No Alarms. IMTPCI GPL version = 126-002-000 BLVXW6 GPL version = 126-002-000 BLDIAG6 GPL version = 126-002-000 BLBEPM GPL version = 126-002-000 BLCPLD GPL version = 126-002-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 32C ( 90F) PEAK TEMPERATURE: = 39C (103F) [06-05-02 13:40] Command Completed.
If the GPL value shown in the rept-stat-card output is IPSHC, the card is an E5-IPSM. If the GPL value shown in the rept-stat-card output is IPS, the card is an IPSM.
If there are a minimum of two E5-IPSMs shown in the rept-stat-card outputs, go to step 4.
If there is only one E5-IPSM or no E5-IPSMs shown in the rept-stat-card outputs, E5-IPSMs must be added to the database so that there are a minimum of two E5-IPSMs in the database. Remove enough IPSMs from the database so that when the E5-IPSMs are added, the EAGLE will contain a minimum of two E5-IPSMs. Perform the Removing an E5-IPSM procedure to remove the IPSMs. After the IPSMs have been removed from the database, remove the IPSM from the shelf.
When the IPSMs have been removed, perform the "Adding an IPSM" procedure in Chapter 4 of this manual to add the E5-IPSMs.
rept-stat-trm command with the number of the selected telnet terminal. For this example, enter these commands. rept-stat-trm:trm=18
rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0 TRM PST SST AST 18 IS-NR Active ----- Command Completed.
rept-stat-trm:trm=27
rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0 TRM PST SST AST 27 IS-NR Active ----- Command Completed.
rmv-trm command. Enter the rmv-trm command with the number of the terminal whose state is not OOS-MT_DSBLD. Perform this step only for the terminals shown in step 4 whose state is not OOS-MT_DSBLD. rmv-trm:trm=18
rmv-trm:trm=27
When these commands have successfully completed, this message should appear.
rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0 Inhibit message sent to terminal rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0 Command Completed.
rept-stat-trm command with the number of the terminal specified in step 5. For this command, enter these commands.
rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0 TRM PST SST AST 18 OOS-MT-DSBLD MANUAL ----- Command Completed.
rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0 TRM PST SST AST 27 OOS-MT-DSBLD MANUAL ----- Command Completed.
chg-trm command with the number of the terminals shown in step 6. For this example enter these commands.
chg-trm:trm=18:type=seas
chg-trm:trm=27:type=seas
rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0 CHG-TRM: MASP A - COMPLTD
rtrv-trm command with the terminal number specified in step 7. For this example, enter these commands.
rtrv-trm:trm=18
18 SEAS 1201 30 5 00:01:00 yes
(sec) (sec) (msec)
18 none none none 1
APP APP
18 NO NO NO NO NO NO NO NO NO NO YES NO
rtrv-trm:trm=27
27 SEAS 1203 30 5 00:01:00 yes
(sec) (sec) (msec)
27 none none none 1
APP APP
27 NO NO NO NO NO NO NO NO NO NO YES NO
rtrv-seas-config command. The following is an example of the possible output if the Eagle OA&M IP Security Enhancement feature is not enabled and turned on.
rlghncxa03w 07-01-23 18:46:01 EST EAGLE 37.5.0
SEASCLLI CONNECTION IPADDRESS PORT TERMINAL
TEAGLESTP001 IPMR1 192.168.25.10 2500 --
IPMR2 192.168.25.20 2600 --
The following is an example of the possible output if the Eagle OA&M IP Security Enhancement feature is enabled and turned on.
rlghncxa03w 07-01-23 18:46:01 EST EAGLE 37.5.0 SEASCLLI AUTHMODE ---------------------------- TEAGLESTP001 Password TERMINAL CONNECTION IPADDR PORT LOGIN HNAME --------------------------------------------------------------------- -- IPMR1 198.168.25.10 2500 root abaco-a -- IPMR2 198.168.25.20 2600 root abaco-b
pass:cmd=”ping” command specifying the card location of the SEAS terminal (shown in step 8) and the IP address assigned to the connection (shown in step 9). Perform this step for both connection to the CCS MR. For this example, enter these commands pass:loc=1201:cmd=”ping 198.168.25.10”
The following is an example of the possible output.
rlghncxa03w 07-05-28 21:15:37 GMT EAGLE5 37.0.0 PASS: Command sent to card rlghncxa03w 07-05-28 21:15:37 GMT EAGLE5 37.0.0 PING command in progress rlghncxa03w 07-05-28 21:15:37 GMT EAGLE5 37.0.0 PING 198.168.25.10: 56 data bytes 64 bytes from tekral.nc.tekelec.com (198.168.25.10): icmp_seq=0. time=5. ms 64 bytes from tekral.nc.tekelec.com (198.168.25.10): icmp_seq=1. time=9. ms 64 bytes from tekral.nc.tekelec.com (198.168.25.10): icmp_seq=2. time=14. ms ----tekral PING Statistics---- 3 packets transmitted, 3 packets received, 0% packet loss round-trip (ms) min/avg/max = 5/9/14 PING command complete
pass:loc=1203:cmd=”ping 198.168.25.20”
rlghncxa03w 07-05-28 21:15:37 GMT EAGLE5 37.0.0 PASS: Command sent to card rlghncxa03w 07-05-28 21:15:37 GMT EAGLE5 37.0.0 PING command in progress rlghncxa03w 07-05-28 21:15:37 GMT EAGLE5 37.0.0 PING 198.168.25.20: 56 data bytes 64 bytes from tekral.nc.tekelec.com (198.168.25.20): icmp_seq=0. time=5. ms 64 bytes from tekral.nc.tekelec.com (198.168.25.20): icmp_seq=1. time=9. ms 64 bytes from tekral.nc.tekelec.com (198.168.25.20): icmp_seq=2. time=14. ms ----tekral PING Statistics---- 3 packets transmitted, 3 packets received, 0% packet loss round-trip (ms) min/avg/max = 5/9/14 PING command complete
alw-trm command with the number of the SEAS terminals shown in step 8. alw-trm:trm=18
When this command has successfully completed, this message should appear.
rlghncxa03w 04-01-07 11:11:28 EST EAGLE 31.3.0 Allow message sent to terminal rlghncxa03w 04-01-07 11:11:28 EST EAGLE 31.3.0 1062.0046 TERMINAL 18 Terminal Enabled
alw-trm:trm=27
rlghncxa03w 04-01-07 11:11:28 EST EAGLE 31.3.0 Allow message sent to terminal rlghncxa03w 04-01-07 11:11:28 EST EAGLE 31.3.0 1062.0046 TERMINAL 27 Terminal Enabled
chg-db:action=backup:dest=fixed command. These messages should appear, the active Maintenance and Administration Subsystem Processor (MASP) appears first.
BACKUP (FIXED) : MASP A - Backup starts on active MASP. BACKUP (FIXED) : MASP A - Backup on active MASP to fixed disk complete. BACKUP (FIXED) : MASP A - Backup starts on standby MASP. BACKUP (FIXED) : MASP A - Backup on standby MASP to fixed disk complete.
Figure 5-6 Configuring SEAS Terminals
Sheet 1 of 3
Sheet 2 of 3
Sheet 3 of 3
