Go to primary content
Oracle® Communications EAGLE Database Administration - System Management User's Guide
Release 46.6
E93319 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Changing Terminal Characteristics
This procedure is used to change the characteristics of a terminal, except for the SEAS terminal and a measurements terminal for an EAGLE containing a maximum of 700 signaling links, using the chg-trm command.
To configure a measurements terminal for an EAGLE containing a maximum of 700 signaling links, go to the Configuring the Measurements Terminal for an EAGLE Containing 700 Signaling Links procedure.
To configure a SEAS terminal, refer to the Configuring SEAS Terminals procedure.
The communication attributes can be changed on any terminal except on the terminal you are logged on to. The message output group assignments can be changed on any terminal, including the terminal you are logged on to. The chg-trm command uses these parameters.
:trm – terminal numbers (1 - 40, terminals 1-16 are serial terminals, terminals 17-40 are telnet terminals).
:baud – Serial port baud rate (2400, 4800, 9600, or 19200, 38400, 57600, 115200). Values 38400, 57600, and 115200 are only valid when the OAMHC is used.
:sb – The number of stop bits used in communications with the device (1 or 2).
:prty – Parity used by the device (odd, even, none).
:type – The type of device being connected (See the "Terminal Types" section).
:fc – The type of flow control used between the EAGLE and the output devices. (sw - software, hw - hardware, both - hardware and software, none).
Hardware flow control (fc=hw) and both hardware and software flow control (fc=both) are not supported for the terminal if the EAGLE contains E5-TDMs. Part of the terminal output may be lost if hardware flow control or both hardware and software flow control are specified for the terminal when the EAGLE contains E5-TDMs.
:tmout – The maximum amount of time, in minutes, that a login session on the specified port can remain idle (that is, no user input) on the port before being automatically logged off. (0 - 99, see the "Security Parameters" section).
:mxinv – The login failure threshold – The number of login attempt failures or attempts to unlock a terminal that can occur on the terminal before the terminal is disabled. (0 - 9, see the "Security Parameters" section).
:dural – The length of time that the terminal is disabled after the login failure threshold has been exceeded. (See the "Security Parameters" section).
:all – Specifies whether or not all unsolicited messages are displayed on the specified terminal (yes or no).
:traf – Specifies whether or not traffic related unsolicited messages are displayed on the specified terminal (yes or no).
:link – Specifies whether or not link maintenance related unsolicited messages are displayed on the specified terminal (yes or no).
:sa – Specifies whether or not security administration related unsolicited messages are displayed on the specified terminal (yes or no).
:db – Specifies whether or not database related unsolicited messages are displayed on the specified terminal (yes or no).
:sys – Specifies whether or not system maintenance related unsolicited messages are displayed on the specified terminal (yes or no).
:pu – Specifies whether or not program update related unsolicited messages are displayed on the specified terminal (yes or no).
:uimrd – Specifies whether or not UIM redirect related unsolicited messages are displayed on the specified terminal (yes or no).
:appserv – Specifies whether or not application server related unsolicited messages are displayed on the specified terminal. (yes or no).
:appss – Specifies whether or not application subsystem related unsolicited messages are displayed on the specified terminal (yes or no).
:card – Specifies whether or not card related unsolicited messages are displayed on the specified terminal (yes or no).
:clk – Specifies whether or not clock related unsolicited messages are displayed on the specified terminal (yes or no).
:dbg – Specifies whether or not debug related unsolicited messages are displayed on the specified terminal (yes or no).
:gtt – Specifies whether or not global title translation related unsolicited messages are displayed on the specified terminal (yes or no).
:gws – Specifies whether or not gateway screening related unsolicited messages are displayed on the specified terminal (yes or no).
:meas – Specifies whether or not measurements maintenance related unsolicited messages are displayed on the specified terminal (yes or no).
:mon – Specifies whether or not unsolicited messages related to the Sentinel monitoring functions are displayed on the specified terminal (yes or no).
:mps – Specifies whether or not MPS related unsolicited messages are displayed on the specified terminal (yes or no).
:seas – Specifies whether or not SEAS maintenance related unsolicited messages are displayed on the specified terminal (yes or no).
:slan – Specifies whether or not SLAN maintenance related unsolicited messages are displayed on the specified terminal (yes or no).
:logintmr – the login timer. This parameter specifies the maximum time for logging on to the telnet terminal after selecting the terminal. This timer makes sure the user logs in with in the configured time and terminal does not remain idle. The value for this timer can be from 3 seconds to 600 seconds. An additional value none indicates that the user has an indefinite amount of time to login on the telnet terminal. The system default value for this parameter is none. This parameter can be specified only for telnet terminals (type=telnet).
:logouttmr – the logout timer. This parameter specifies the maximum time the telnet session remains open after the user manually or automatically logs out. The value for this timer can be from 0 to 1200 seconds. An additional value none indicates that the telnet session is never closed when the user logs out. The system default value for this parameter is none. This parameter can be specified only for telnet terminals (type=telnet).
:pngtimeint – the ping timer interval. This parameter specifies the amount of time that must pass before the IPSM initiates a new ping cycle. The value for this timer can be from 100 to 1200000 milliseconds. An additional value none indicates that pinging does not occur. The system default value for this parameter is none. This parameter can be specified only for telnet terminals (type=telnet) and EMSALM terminals (type=emsalm).
:pngfailcnt – This parameter specifies the number of consecutive ping fails that must occur before the telnet connection is dropped. The value for this timer can be from 1 to 10. The system default value for this parameter is 1. This parameter can be specified only for telnet terminals (type=telnet) and EMSALM terminals (type=emsalm).
The messages assigned to the output message groups defined by the traf, db, link, sa, sys, pu, uimrd, appserv, appss, card, clk, dbg, gtt, gws, meas, mon, mps, seas, and slan parameters are listed in Unsolicited Alarm and Information Messages Reference .
Certain UIMs (unsolicited information messages) can be assigned to the UIM Redirect output group or remain in their original output message group. The uimrd parameter of the chg-trm command and the on=uimrd and off=uimrd parameters of the chg-stpopts command determine which output groups these UIMs are assigned to and how the EAGLE handles them.
The on=uimrd parameter of the chg-stpopts command tells the EAGLE to put these UIMs in the unsolicited UIM Redirect output message group. If the off=uimrd parameter is specified with the chg-stpopts command, the messages remain in their original output message group. The on=uimrd parameter value of the chg-stpopts command is shown in the UIMRD row of the rtrv-stpopts output as the value yes. The off=uimrd parameter value of the chg-stpopts command is shown in the UIMRD row of the rtrv-stpopts output as the value no. The uimrd=yes parameter of the chg-trm command allows the specified terminals to receive unsolicited UIM redirect output messages.
Table 4-2 shows the combination of the values of both uimrd values and how the EAGLE handles the messages. The unsolicited output group message assignments are listed in Unsolicited Alarm and Information Messages Reference.
Table 4-2 UIMRD Parameter Combinations
UIMRD value of the terminal UIMRD STP option value Action
No
No (See Note 1)
The UIMs remain in their original output message group and are output to terminals receiving messages from the original output message group.
No
Yes (See Note 2)
The UIMs are in the UIM Redirect output group but are not output to any terminal.
Yes
No (See Note 1)
Even though the UIMRD value for the terminal is yes, there are no messages in the UIM redirect output group because the UIMRD value in the rtrv-stpopts output is no.
No UIM redirect messages are output to any terminal.
Yes
Yes (See Note 2)
The UIMs are in the UIM Redirect output group and are output to terminals receiving unsolicited UIM redirect messages.
Notes:
  1. This value is set with theoff=uimrdparameter of thechg-stpoptscommand.
  2. This value is set with theon=uimrdparameter of thechg-stpoptscommand.
If the type=vt320 or type=sccs parameters are specified, the value of the prty parameter cannot be none. The value of the prty parameter must be either odd or even.
The EAGLE requires at least two terminals assigned to the Security Administration command class. The terminal type of a terminal assigned to the Security Administration command class cannot be changed to these terminal types, printer (:type=printer) or none (:type=none) if the change would leave the EAGLE with only one terminal assigned to the Security Administration command class. The command class assignments of the terminal are shown with the rtrv-secu-trm command. If the terminal type is being changed to either printer or none, go to the Changing Terminal Command Class Assignments procedure and make sure that the command class assignment for the terminal being changed does not have the Security Administration command class assigned to it, or change the command class assignment of another terminal to include the Security Administration command class.
If the all=yes parameter and the traf, db, link, sa, sys, pu, uimrd, appserv, appss, card, clk, dbg, gtt, gws, meas, mon, mps, seas, or slan parameters are specified, for example, chg-trm:trm=1:all=yes:pu=no; all the message output groups are set to yes with the exception of the message output groups specified in the chg-trm command which are set to no. In this example, the value of all the message output groups is yes (all=yes) with the exception of the program update message output group which has the value no (pu=no).
If the all=no parameter is specified for a SEAS terminal (type=seas), all the output group values are changed to NO except for the SEAS output group. The SEAS output group value remains set to YES and this message is displayed.
SEAS Output Group is SET for SEAS terminal <terminal number>
The total value of the terminals’ baud rate cannot be greater than 172,032. If the total baud rate of the terminals exceeds 172,032, change the baud rates of the terminals so that the total baud rate is not greater than 172,032.
Only four terminals should be configured to receive unsolicited system maintenance messages (:sys=yes).
If the communication attributes (baud, sb, prty, and fc) or the terminal type (type) for the terminal are being changed, the terminal must be placed out of service with the rmv-trm command before the changes can be made.
If only the output message group or security (tmout, mxinv, dural) parameters are being changed, the terminal can remain in service when the chg-trm command is executed.
Terminal Types
There are nine terminal types that can be used on the EAGLE.
The VT320 type is the standard terminal used for entering commands, displaying command responses, displaying periodic system status information at screen specific locations, and scrolling unsolicited messages.
The PRINTER type is used with printers for recording UAMs, UIMs and echoed command responses.
The KSR type mimics older style teleprinters (that is, printers with a keyboard).
The SCCS type is used for some network monitoring and surveillance applications. SCCS terminals are the same as KSR terminals, except a pre-defined “start-of-message” character is added to indicate the beginning of a new command response or unsolicited message.
The NONE type is typically used to indicate unused terminals.
The MGMT terminal type, or management terminal, provides a machine to machine messaging interface between the EAGLE and the customer’s network to provide network surveillance.
The TELNET terminal type provides up to 24 IP based connections to the EAGLE’s user interface using a telnet client, in addition to the 16 RS-232 terminals. The telnet terminals are numbered from 17 to 40. The telnet terminals are configured automatically when the IP User Interface (Telnet) feature is enabled and activated, and when the IPSMs are configured in the database. The EAGLE can have 3 IPSMs, with each IPSM supporting eight telnet terminals. The baud, prty, sb, and fc parameters cannot be specified with the chg-trm command for a telnet terminal, but all other terminal parameters can be specified and changed for a telnet terminal. For terminals 17 to 40, the values for the type parameter can be only telnet, none, or emsalm.
If the chg-trm command is executed from a telnet terminal (terminals 17 to 40), only the output group parameters (all, traf, link, sa, db, sys, pu, uimrd, appserv, appss, card, clk, dbg, gtt, gws, meas, mon, mps, seas, slan) and the terminal type can be changed.
The EMSALM terminal type provides an alarm monitoring capability that displays only UAMs and system alive messages generated by the EAGLE. UIMs and autonomous reports are not displayed on the EMSALM terminals, even if the output group settings for these terminals would allow these messages to be displayed on these terminals.
Caution:
EMSALM terminals can accept login requests and commands; however, these operations may interfere with the alarm monitoring functions of the EMSALM terminals and should be performed on another terminal.
The EMSALM terminal type can be assigned to any terminal, serial (terminals 1 to 16) or telnet (terminals 17 to 40). When the terminal type is changed to emsalm, all the output message group settings for that terminal are set to yes, even if any of the output message groups were set to no before the terminal type change. These output message group settings can be changed, if desired. The communications attributes (baud, prty, sb, fc) and security parameter values (tmout, mxinv, dural) are not changed.
Caution:
It is recommended that all the output message group settings for an EMSALM terminal are set to yes. Changing any of the output message group settings to no could prevent alarm messages controlled by the output message group from being displayed on the EMSALM terminal.
Caution:
If a terminal dedicated to measurements collection is configured (see the Configuring the Measurements Terminal for an EAGLE Containing 700 Signaling Links procedure), it is recommended that this terminal is not changed to an EMSALM terminal.
When the terminal type is changed from emsalm to another terminal type, the output message group settings, communications attributes, and security parameter values are not changed.
When assigning the EMSALM terminal type to a serial terminal, the communication attribute (baud, prty, sb, fc), security (tmout, mxinv, dural), and output group (traf, db, link, sa, sys, uimrd, appserv, appss, card, clk, dbg, gtt, gws, meas, mon, mps, seas, slan) parameters values can be changed.
When assigning the EMSALM terminal type to a telnet terminal, only the security (tmout, mxinv, dural), and output group (traf, db, link, sa, sys, pu, uimrd, appserv, appss, card, clk, dbg, gtt, gws, meas, mon, mps, seas, slan) parameters values can be changed.
The SEAS terminal type is used to provide a path between the EAGLE and the CCS MR to support the SEAS over IP feature. The SEAS terminal type is not used in this procedure. To configure a terminal as a SEAS terminal, refer to the Configuring SEAS Terminals procedure.
Security Parameters
The monitoring of a terminal’s idle time (tmout) and the automatic logout function only applies to terminal types VT320 (type=vt320), KSR, (type=ksr), SCCS (type=sccs), and MGMT (type=mgmt). The tmout parameter can be specified with other terminal types, but it will have no effect. The system default value for the tmout parameter is 30 minutes. The tmout=0 parameter value allows the terminal to remain idle indefinitely without being automatically logged off.
To impose a temporary lockout of a terminal after a particular number of login attempt failures or a particular number of attempts to unlock a terminal have occurred, the mxinv and dural values for that terminal must be greater than 0.
The mxinv=0 parameter value prevents any temporary lockout of the terminal regardless of the number of successive failed login or unlock attempts that were made at the terminal. No messages are issued regarding the temporary lockout. This action applies even if the dural parameter value is greater than 0.
The dural=0 parameter prevents the terminal from being temporarily locked out. If the mxinv parameter value is greater than 0 and the dural parameter value is 0, the EAGLE issues messages concerning login failure threshold, but the terminal will not be locked out.
The value of the dural parameter can be expressed in seconds (0 - 59), minutes and seconds (0 - 5959), or hours, minutes, and seconds (0 - 995959). The value 999999 for the dural parameter disables the terminal, when the login failure threshold has been exceeded, for an indefinite period of time. A terminal that is disabled for an indefinite period of time is identified by the entry INDEF in the DURAL field of the rtrv-trm command output. A terminal disabled indefinitely can only be restored to service by inhibiting the terminal with the rmv-trm command, then placing it into service with the rst-trm command.
When the EAGLE is delivered to the user, the mxinv and dural parameters will be set to these values:
:mxinv = 5
:dural = 0100 (1 minute, 0 seconds)
The RTRV-TRM Output
The output of the rtrv-trm command is displayed in two parts. The first part displays the communication and security attributes of the terminal. The communication attributes of the terminal, BAUD, PRTY (parity), SB (stop bits), and DBTS (data bits), are displayed in the COMM field of the rtrv-trm output and are displayed in this format: BAUD–DBTS–PRTY–SB. The type of flow control used by the terminal is shown in the FC field. The security attributes of the terminal are shown in the TMOUT, MXINV, and DURAL fields. The second part of the rtrv-trm command output displays the types of unsolicited messages the terminal may receive. An example of the rtrv-trm command output is shown in this example.
rlghncxa03w 06-10-01 16:02:08 GMT EAGLE5 36.0.0
TRM  TYPE    COMM        FC    TMOUT MXINV DURAL
3    VT320    9600-7-E-1 SW    30    5     99:59:59
TRM  TRAF LINK SA  SYS PU  DB  UIMRD
3    NO   YES  NO  YES NO  YES YES
     APP  APP
TRM  SERV SS  CARD CLK DBG GTT GWS MEAS MON MPS SEAS SLAN
3    YES  YES YES  YES YES YES YES YES  YES YES NO   NO
In this example, terminal 3 is running at 9600 baud with 7 data bits, even parity, and 1 stop bit.
For terminals 17 to 40, the COMM and FC fields are not displayed in the rtrv-trm output. The following items are displayed for these terminals in addition to the security attributes and the types of unsolicited messages the terminal may receive. An example rtrv-trm output example follows the list.
  • The card location of the IPSM associated with the terminals.
  • The security status of the terminal is displayed in the SECURE field. If the Eagle OA&M IP Security Enhancements feature is on, the terminal is secure. The entry yes is shown in the SECURE field. If the Eagle OA&M IP Security Enhancements feature is off, the terminal is not secure. The entry no is shown in the SECURE field. Controlled Feature Activation Procedures contains the procedures to enable and turn on, or turn off the Eagle OA&M IP Security Enhancements feature.
  • The login timer (LOGINTMR), logout timer (LOGOUTTMR), ping time out timer (PNGTIMEINT), and the ping fail count (PNGFAILCNT) values.
rlghncxa03w 06-10-01 16:02:08 GMT EAGLE5 39.0.0
TRM  TYPE    LOC         TMOUT MXINV DURAL     SECURE
30   TELNET  1204        60    0     00:00:00  no
TRM  LOGINTMR LOGOUTTMR PNGTIMEINT PNGFAILCNT
     (sec)    (sec)     (msec)
30   none     none      none       1
30   YES  YES  YES YES YES YES YES
     APP  APP
30   YES  YES YES  YES YES YES YES YES  YES YES NO   NO
Using Telnet Terminals in Place of Serial Terminals
If the Eagle OA&M IP Security feature is disabled and turned off , serial terminals must be connected to the EAGLE and provisioned in the database because Security Administration commands cannot be executed from a telnet terminal.
If the Eagle OA&M IP Security feature is enabled and on, Security Administration commands, in addition to all other commands, can be executed from a telnet terminal only if the Eagle OA&M IP Security feature is enabled and on. The ability to execute commands from a particular terminal is dependent on the terminal command class assignments for that terminal. Even with the ability to execute most EAGLE commands from a telnet terminal, it is recommended that at least two serial terminals remain connected to the EAGLE. The act-echo, lock, and unlock commands cannot be executed from a telnet terminal. These terminals should be configured with at least Security Administration command class privileges.
By having serial terminals connected to the EAGLE, the user would still have access to the EAGLE in the event of a telnet terminal connection failure.
Upgrades of the EAGLE from a telnet terminal are not supported. When the EAGLE is upgraded, the MASPs are upgraded first, followed by the various cards in the EAGLE. The cards are upgraded by taking the cards out of service, then placing the cards back into service. When the IPSMs are taken out of service, the telnet sessions running on the IPSMs are disabled. This can result in losing the telnet terminal connection to the EAGLE. The Expanded Terminal Output Groups feature can create a situation where UIMs required for the upgrade would not be displayed on the same telnet terminal that initiated the upgrade. The upgrade would be difficult to complete if the UIMs generated during the upgrade are not displayed on the same telnet terminal that initiated the upgrade.
The EAGLE upgrade procedure recommends that some method to capture command input and output during the upgrade process is used. The telnet terminals do not support capturing the input and output, nor can the EAGLE’s act-echo command be used on a telnet terminal. Because of this limitation, the upgrade procedure should not be executed from a telnet terminal.
For any EAGLE release, whether the Eagle OA&M IP Security feature is enabled or not, if applicable, Kermit file transfers, required for the Security Log feature, are not supported from telnet terminals. The Kermit file transfers can be performed only from a serial terminal.
  1. Display the values of all terminals using the rtrv-trm command.
    This is an example of the possible output.
    1    VT320    9600-7-E-1  SW    30    5     99:59:59
    2    KSR      9600-7-E-1  HW    30    5     INDEF
    3    PRINTER  4800-7-E-1  HW    30    0     00:00:00
    4    VT320    2400-7-E-1  BOTH  30    5     00:30:00
    5    VT320    9600-7-O-1  NONE  30    5     00:00:30
    6    VT320    9600-7-E-2  SW    30    9     INDEF
    7    PRINTER  9600-7-E–2  HW    30    5     00:30:00
    8    KSR     19200-7-E-2  BOTH  30    5     00:30:00
    9    VT320    9600-7-E-1  SW    30    7     00:30:00
    10   VT320    9600-7-E-1  HW    30    5     00:30:00
    11   VT320    4800-7-E-1  HW    30    5     00:30:00
    12   PRINTER  9600-7-E-1  HW    30    4     00:30:00
    13   VT320    9600-7-O-1  NONE  30    5     00:30:00
    14   VT320    9600-7-E-2  SW    30    8     00:30:00
    15   VT320    9600-7-E–2  HW    30    5     00:30:00
    16   VT320    9600-7-E-2  BOTH  30    3     00:30:00
    17   TELNET    1201             60    5     00:30:00   yes
    18   TELNET    1201             60    5     00:30:00   yes
    19   TELNET    1201             60    5     00:30:00   yes
    20   TELNET    1201             60    5     00:30:00   yes
    21   TELNET    1201             60    5     00:30:00   yes
    22   TELNET    1201             60    5     00:30:00   yes
    23   TELNET    1201             60    5     00:30:00   yes
    24   TELNET    1201             60    5     00:30:00   yes
         (sec)    (sec)     (msec)
    17   none     none      none       1
    18   none     none      none       1
    19   none     none      none       1
    20   none     none      none       1
    21   none     none      none       1
    22   none     none      none       1
    23   none     none      none       1
    24   none     none      none       1
    1    NO   YES  NO  YES NO  YES YES
    2    NO   NO   NO  NO  NO  NO  NO
    3    YES  YES  YES NO  YES YES YES
    4    YES  NO   NO  NO  NO  NO  NO
    5    NO   YES  NO  NO  NO  NO  YES
    6    NO   NO   YES NO  NO  NO  NO
    7    YES  YES  YES YES YES YES YES
    8    NO   NO   NO  NO  YES NO  YES
    9    NO   YES  NO  NO  NO  YES NO
    10   NO   NO   NO  NO  NO  NO  YES
    11   YES  YES  YES YES YES YES YES
    12   YES  YES  YES YES YES YES YES
    13   NO   YES  NO  NO  NO  NO  YES
    14   NO   NO   YES NO  NO  NO  NO
    15   YES  YES  YES NO  YES YES YES
    16   NO   NO   NO  NO  YES NO  YES
    17   NO   NO   NO  NO  NO  NO  NO
    18   NO   NO   NO  NO  NO  NO  NO
    19   NO   NO   NO  NO  NO  NO  NO
    20   NO   NO   NO  NO  NO  NO  NO
    21   NO   NO   NO  NO  NO  NO  NO
    22   NO   NO   NO  NO  NO  NO  NO
    23   NO   NO   NO  NO  NO  NO  NO
    24   NO   NO   NO  NO  NO  NO  NO
        APP  APP
    1    YES  YES YES  YES YES YES YES YES  YES YES NO   NO
    2    YES  YES YES  YES YES YES YES YES  YES YES NO   NO
    4    YES  YES YES  YES YES NO  YES YES  YES YES NO   NO
    5    YES  YES YES  YES YES YES YES YES  YES YES NO   NO
    6    YES  YES YES  YES YES YES YES YES  YES YES NO   NO
    7    NO   YES YES  YES YES YES YES YES  YES YES NO   NO
    8    YES  YES YES  YES YES YES YES YES  YES YES YES  YES
    9    YES  YES YES  YES YES YES YES YES  YES YES YES  YES
    10   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    11   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    12   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    13   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    14   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    15   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    16   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    17   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    18   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    19   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    20   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    21   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    22   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    23   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    24   NO   NO  NO   NO  NO  NO  NO  NO   NO  NO  NO   NO
    If a telnet terminal is being changed, continue the procedure with 2.
    If telnet terminals are not being added in this procedure, continue the procedure by performing one of these steps.
    • If the terminal type or the communication attributes of the terminal are being changed, or the pngtimeint, pngfailcnt parameters of an EMSALM terminal are being changed, continue the procedure with 3.
    • If only the output message group or security parameters for the terminal are being changed, continue the procedure with 7.
  2. If the rtrv-trm output in 1 shows terminals 1 to 16 and you wish to add telnet terminals (type=telnet, terminals 17 through 40), go to the Adding an E5-IPSM procedure.
    Adding an IPSM adds eight telnet terminals to the EAGLE.
    When an IPSM is added to the database, the eight telnet terminals associated with the IPSM are added to the database with the telnet terminal type and the default values for these parameters.
    • The security (tmout, mxinv, dural) parameters.
    • The output message group (traf, db, link, sa, sys, pu, uimrd, appserv, appss, card, clk, dbg, gtt, gws, meas, mon, mps, seas, slan) parameters
    • The logintmr, logouttmr, pngtimeint, pngfailcnt parameters.
    The only actions that can be performed on terminals 17 through 40 is changing the terminal type to either none, telnet, or emsalm, and changing the security (tmout, mxinv, dural), changing the output message group (traf, db, link, sa, sys, pu, uimrd, appserv, appss, card, clk, dbg, gtt, gws, meas, mon, mps, seas, slan) parameters, or changing the logintmr, logouttmr, pngtimeint, pngfailcnt parameters.
    If no changes are being made to the telnet terminals, either to the existing telnet terminals, or to the telnet terminals that were added in this step with “Adding an E5-IPSM“ procedure, this procedure is finished.
    If changes are being made to the telnet terminals, continue the procedure by performing one of these steps.
    • If only the output message group or security parameters are being changed, continue the procedure with 7 .
    • If the terminal type or the logintmr, logouttmr, pngtimeint, pngfailcnt parameters are being changed, continue the procedure with 3.
  3. Display the status of the terminals by entering the rept-stat-trm command.
    This is an example of the possible output (another IPSM added from 2).
    rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 36.0.0
    TRM   PST           SST           AST
    1     IS-NR         Active        -----
    2     IS-NR         Active        -----
    3     IS-NR         Active        -----
    4     IS-NR         Active        -----
    5     IS-NR         Active        -----
    6     IS-NR         Active        -----
    7     IS-NR         Active        -----
    8     IS-NR         Active        -----
    9     IS-NR         Active        -----
    10    IS-NR         Active        -----
    11    IS-NR         Active        -----
    12    IS-NR         Active        -----
    13    IS-NR         Active        -----
    14    IS-NR         Active        -----
    15    IS-NR         Active        -----
    16    IS-NR         Active        -----
    17    IS-NR         Active        -----
    18    IS-NR         Active        -----
    19    IS-NR         Active        -----
    20    IS-NR         Active        -----
    21    IS-NR         Active        -----
    22    IS-NR         Active        -----
    23    IS-NR         Active        -----
    24    IS-NR         Active        -----
    25    IS-NR         Active        -----
    26    IS-NR         Active        -----
    27    IS-NR         Active        -----
    28    IS-NR         Active        -----
    29    IS-NR         Active        -----
    30    IS-NR         Active        -----
    31    IS-NR         Active        -----
    32    IS-NR         Active        -----
    Command Completed.
    If the status of the terminal that is being changed is OOS-MT-DSBLD, and the terminal type is being changed to printer or none, continue the procedure with 6.
    If the status of the terminal that is being changed is OOS-MT-DSBLD, and the terminal type is not being changed to printer or none, continue the procedure with 7.
    If the status of the terminal that is being changed is not OOS-MT-DSBLD, continue the procedure with 4.
  4. Inhibit the terminal you wish to change using the rmv-trm command and specify the port you wish to inhibit.
    rmv-trm:trm=4
    rmv-trm:trm=8
    rmv-trm:trm=19
    rmv-trm:trm=23
    rmv-trm:trm=21
    When these commands have successfully completed, this message should appear.
    Inhibit message sent to terminal
    Command Completed.
  5. Verify that the terminal that was inhibited in 4 is in the OOS-MT-DSBLD state by entering the rept-stat-trm command.
    For this command, enter these commands.
    rept-stat-trm:trm=4
    TRM   PST            SST           AST
    4     OOS-MT-DSBLD   MANUAL        -----
    Command Completed.
    rept-stat-trm:trm=8
    TRM   PST            SST           AST
    8     OOS-MT-DSBLD   MANUAL        -----
    Command Completed.
    rept-stat-trm:trm=19
    TRM   PST            SST           AST
    19    OOS-MT-DSBLD   MANUAL        -----
    Command Completed.
    rept-stat-trm:trm=23
    TRM   PST            SST           AST
    23    OOS-MT-DSBLD   MANUAL        -----
    Command Completed.
    rept-stat-trm:trm=21
    rlghncxa03w 06-10-01 15:08:45 GMT EAGLE5 39.0.0
    TRM   PST            SST           AST
    21    OOS-MT-DSBLD   MANUAL        -----
    Command Completed.
    If the terminal type is not being changed to either printer or none, continue the procedure with 7.
    If the terminal type is being changed to either printer or none, continue the procedure with 6.
  6. Display the command class values of all terminals using the rtrv-secu-trm command.
    rlghncxa03w 06-10-01 12:31:04 GMT EAGLE5 36.0.0
    TRM    LINK SA  SYS  PU   DB   DBG
    1      NO   NO  YES  NO   YES  NO
    2      NO   NO  NO   NO   YES  NO
    3      YES  *** YES  YES  YES  YES
    4      NO   YES NO   NO   NO   NO
    5      YES  NO  NO   NO   YES  YES
    6      NO   YES NO   NO   NO   NO
    7      NO   *** YES  NO   YES  NO
    8      NO   NO  NO   NO   NO   NO
    11     YES  NO  YES  NO   YES  YES
    12     NO   *** NO   NO   NO   NO
    13     NO   NO  NO   NO   YES  YES
    14     NO   YES NO   NO   YES  YES
    15     NO   NO  NO   NO   YES  YES
    16     NO   NO  NO   NO   YES  YES
    17     NO   NO  YES  NO   YES  NO
    18     NO   NO  NO   NO   YES  NO
    19     YES  NO  YES  YES  YES  YES
    20     NO   YES NO   NO   NO   NO
    21     YES  NO  NO   NO   YES  YES
    22     NO   YES NO   NO   NO   NO
    23     NO   NO  YES  NO   YES  NO
    25     YES  YES YES  YES  YES  YES
    26     NO   NO  NO   NO   NO   NO
    27     YES  NO  YES  NO   YES  YES
    28     NO   NO  NO   NO   NO   NO
    29     NO   NO  NO   NO   YES  YES
    30     NO   YES NO   NO   YES  YES
    31     NO   NO  NO   NO   YES  YES
    32     NO   NO  NO   NO   YES  YES
    If the terminal type is being changed to either printer or none, make sure the EAGLE has at least two terminals assigned to the Security Administration command class (shown in the SA column in the rtrv-secu-trm output). If the terminal being changed in this procedure is being removed from the Security Administration command class, and if this change would leave the EAGLE with only one terminal assigned to the Security Administration command class, go to the Changing Terminal Command Class Assignments procedure and change the command class assignment of another terminal to include the Security Administration command class.
  7. Display the UIMRD STP option value by entering the rtrv-stpopts command. This is an example of the possible output.
    rlghncxa03w 10-07-17 16:02:05 GMT  EAGLE5 42.0.0
    STP OPTIONS
    UIMRD               yes
    The rtrv-stpopts command output contains other fields that are not used by this procedure. If you wish to see all the fields displayed by the rtrv-stpopts command, see the rtrv-stpopts command description in Commands User's Guide.
    The EAGLE sends UIMs to the terminals based on the value of the UIMRD field in the rtrv-stpopts output and the UIMRD value for the terminal. The interaction of these two values is shown in Table 4-2.
    If you do not wish to change how the EAGLE handles sends UIMs to the terminal, continue the procedure with 11 and do not change the UIMRD value for the terminal.
    If you do not wish to change how the EAGLE handles sends UIMs to the terminal, continue the procedure with 10. When 11 is performed, do not change the UIMRD value for the terminal.
    If you wish to change how the EAGLE handles sends UIMs to the terminal, continue the procedure with 8.
  8. Change the UIMRD STP option value.
    To turn the UIMRD STP option on, enter this command.
    chg-stpopts:on=uimrd
    To turn the UIMRD STP option off, enter this command.
    chg-stpopts:off=uimrd
    When the command has successfully completed, this message should appear.
    rlghncxa03w 10-07-01 15:08:45 GMT EAGLE5 42.0.0
    CHG-STPOPTS: MASP A - COMPLTD
  9. Verify the changes using the rtrv-stpopts command.
    If the on=uimrd parameter was specified in 8, this is an example of the possible output.
    STP OPTIONS
    UIMRD               yes
    If the off=uimrd parameter was specified in 8, this is an example of the possible output.
    STP OPTIONS
    UIMRD                no
    If you do not wish to change the UIMRD value for the terminal, continue the procedure with 11 without specifying the uimrd parameter.
    If you wish to change the UIMRD value for the terminal, continue the procedure with 11. Specify the uimrd parameter with a value, yes or no, that will change the current value for the terminal.
    Continue the procedure with 10.
    If you do not wish to change the UIMRD value for the terminal, when 11 is performed do not specify the uimrd parameter.
    If you wish to change the UIMRD value for the terminal, when 11 is performed specify the uimrd parameter with a value, yes or no.
  10. Verify the TDMs that are in the EAGLE by entering these commands.
    rept-stat-card:loc=1114
    rlghncxa03w 10-12-17 16:02:05 GMT  EAGLE5 43.0.0
    CARD   VERSION      TYPE      GPL        PST            SST        AST
    1114   -----------  E5TDM                IS-NR          Active     -----
    Command Completed.
    rept-stat-card:loc=1116
    1116   -----------  E5TDM                IS-NR          Active     -----
    Command Completed.
    E5-TDMs are shown by the entry E5TDM in the TYPE column. TDMs are shown by the entry TDM in the TYPE column. Hardware flow control (fc=hw) and both hardware and software flow control (fc=both) are not supported for the terminal if the EAGLE contains E5-TDMs. Part of the terminal output may be lost if hardware flow control is specified for the terminal when the EAGLE contains E5-TDMs.
  11. Change the terminal characteristics using the chg-trm command.
    For this example enter these commands.
    chg-trm:trm=4:baud=9600:traf=no:link=yes:sa=yes:db=yes
    chg-trm:trm=19:type=none
    chg-trm:trm=21:sys=yes:link=yes:sa=yes:db=yes:tmout=30:logintmr=30:logouttmr=60 :pngtimeint=1000:pngfailcnt=3
    chg-trm:trm=8:type=emsalm
    chg-trm:trm=23:type=emsalm
    If 4 was not performed in this procedure (placing the terminal out of service), do not specify these parameters with thechg-trm command:
    • baud, sb, prty, fc (the communications attributes of the terminal).
      These parameters cannot be specified for terminals 17 to 40.
    • the terminal type (type).
    • the logintmr, logouttmr, pngtimeint, pngfailcnt parameters
    Caution:
    If the terminal type is being changed to emsalm, it is recommended that all the output message group settings for an EMSALM terminal are set to yes. Changing any of the output message group settings to no could prevent alarm messages controlled by the output message group from being displayed on the EMSALM terminal.
    Caution:
    CHG-TRM: MASP A - COMPLTD
  12. Verify the changes made in 11 by using the rtrv-trm command with the terminal number specified in 11 .
    For this example, enter these commands.
    rtrv-trm:trm=4
    4    VT320    9600-7-E-1 BOTH  30    5     00:30:00
    4    NO   YES  YES NO  NO  YES NO
         APP  APP
    rtrv-trm:trm=19
    19   NONE      1201             60    5     00:30:00   yes
         APP  APP
    rtrv-trm:trm=21
    21   TELNET    1201             30    5     00:30:00   yes
         (sec)    (sec)     (msec)
    21   30        60       1000       3
    21   NO   YES  YES YES NO  YES NO
         APP  APP
    rtrv-trm:trm=8
    8    EMSALM  19200-7-E-2  BOTH  30    5     00:30:00
         APP  APP
    rtrv-trm:trm=23
    23   EMSALM    1201             60    5     00:30:00   yes
    TRM  PNGTIMEINT PNGFAILCNT
         (msec)
    23   none       1
    23   YES  YES  YES YES YES YES YES YES YES
         APP  APP
    23   YES  YES YES  YES YES YES YES YES  YES YES YES  YES
    If there terminal was not inhibited in 4, continue the procedure with 13.
  13. When the changes are complete, and if the terminal was inhibited in 4, activate the terminal using the rst-trm command.
    rst-trm:trm=4
    rst-trm:trm=8
    rst-trm:trm=19
    rst-trm:trm=23
    rst-trm:trm=21
    Allow message sent to terminal
  14. Back up the new changes using the chg-db:action=backup:dest=fixed command.
    These messages should appear, the active Maintenance and Administration Subsystem Processor (MASP) appears first.
    BACKUP (FIXED) : MASP A - Backup starts on active MASP.
    BACKUP (FIXED) : MASP A - Backup on active MASP to fixed disk complete.
    BACKUP (FIXED) : MASP A - Backup starts on standby MASP.
    BACKUP (FIXED) : MASP A - Backup on standby MASP to fixed disk complete.
Figure 4-10 Changing Terminal Characteristics
Sheet 1 of 6
Sheet 2 of 6
Sheet 3 of 6
Sheet 4 of 6
Sheet 5 of 6
Sheet 6 of 6
