Resolution Of Known Issues
- Platform Data Collection Error
Issue: TKSPLATMI39 – Platform Data Collection Error (5000004000000000) is observed on Eagle
Description: The Platform Data Collector is a TPD tool that periodically collects various software and hardware information about the server. It helps the customer to collect hardware and software information of all the servers in a 'Discovery Domain'.
For the E5Appb, one of the collection modules attempts to get the psoc version, and fails.rept-stat-mps VERSION PST SST AST EPAP B 016-003-000 IS-ANR Fault Active MINOR PLATFORM ALARM DATA = H'5000004000000000 ALARM STATUS = *0374 Minor Platform Failure(s)Solution:
Run the following command to clear the alarm. Use sudo if running as admusr.
$ /usr/TKLC/plat/bin/pdcAdm - This is for Bug 28486392.
Issue: MySQL Lock Wait Timeout Exceeded alarm in EPAP.
Description: When large-scale data provisioning happens in a short span of time, sometimes MySQL lock wait times out and an alarm (MySQL Lock Wait Timeout Exceeded) is raised in EPAP. The provisioning is not disturbed.
Solution:
Restart the PDBA software.
On the menu, click
PDBA, selectProcess Controland clickStart PDBA software. - This is for Bug 26173039
Issue: GUI does not open in Backup PROV network in https mode after disaster recovery procedure.
Description: After Disaster recovery, GUI does not open in Backup PROV network in https mode.
Solution:
Reconfigure the backup prov IPs from epapconfig menu.
On the
epapconfigmenu, ConfigureNetwork InterfacesMenu, ConfigureProvisioning Networkand then ConfigureBackup Provisioning Network.
