Table of Contents
1. About This Manual
1.1 Introduction
1.2 Related Documents
1.3 Audience
1.4 Organization
1.5 Conventions Used in this Manual
1.5.1 General Conventions
1.5.2 Keyboard Conventions
1.6 Glossary of Icons
1.7 Abbreviations and Acronyms
1.8 Getting Help
2. Administration
2.1 Purge Frequency Maintenance
2.1.1 Invoking Purge Frequency Maintenance Detail Screen
2.2 Purge Frequency Summary Screen
2.2.1 Retrieving Record in Purge Frequency Summary Screen
2.2.2 Editing Purge Frequency Maintenance
2.2.3 Viewing Purge Frequency Maintenance record
2.2.4 Deleting Purge Frequency Maintenance record
2.2.5 Authorizing Purge Frequency Maintenance
2.2.6 Amending Purge Frequency Maintenance
2.2.7 Authorizing Amended Purge Frequency Maintenance
2.2.8 Copying Attributes
2.3 Purge Use Case Maintenance
2.3.1 Invoking Purge Use Case Maintenance Screen
2.4 Purge Use Case Maintenance Summary
2.4.1 Retrieving Record in Purge Use Case Record
2.4.2 Editing Purge Use Case Record
2.4.3 Viewing Purge Use Case Record
2.4.4 Deleting Purge Use Case Record
2.4.5 Authorizing Purge Use Case Record
2.4.6 Amending Purge Use Case Record
2.4.7 Authorizing Amended Purge Use Case Record
2.5 Purge View
2.5.1 Invoking Purge View Screen
2.6 Purge Batch
2.6.1 Invoking Purge Batch Screen
2.7 Purge Processing
2.7.1 Invoking Purge Processing Screen
3. Long Term Data Store
3.1 LDS Module Setup Maintenance
3.1.1 Invoking LDS Module Setup Maintenance Screen
3.2 LDS Module Set Up Summary
3.2.1 Retrieving Record in LDS Module Set Up Summary Screen
3.2.2 Editing LDS Module Set Up Record
3.2.3 Viewing LDS Module Set Up Record
3.2.4 Deleting LDS Module Set Up Record
3.2.5 Authorizing LDS Module Set Up Record
3.3 Pre Process Check
3.3.1 Invoking LDS Pre Process Screen
3.4 LDS Status
3.4.1 Invoking LDS Status Screen
3.5 LDS Process
3.5.1 Invoking LDS Process Screen
3.6 LDS Process Flow
4. Function ID Glossary
