Configuring Accounting
Overview
This chapter provides you with information about configuring RADIUS accounting on your OCSBC including these essential configurations and specialized features:
- Accounting for SIP and H.323
- Local CDR storage on the OCSBC, including CSV file format settings-
- The ability to send CDRs via FTP to a RADIUS sever
- Per-realm accounting control
- Configurable intermediate period
- RADIUS CDR redundancy
- RADIUS CDR content control
This section explains SIP and H.323 accounting using the RADIUS Accounting System (RAS).
For accounting purposes, the OCSBC uses RADIUS to send accounting messages. These messages are transmitted to one of a predefined list of accounting servers using a predefined forwarding strategy. RAS provides a mechanism for temporarily storing session initiation and completion statistics and for delivering these statistics to accounting servers located elsewhere in the network.
Call Detail Records
The OCSBC supports CDRs through RADIUS reporting with additional VSAs to include information that is not available with the standard RADIUS session information. CDRs provide billing information on sessions traversed through a system, as well as troubleshooting information, fraud detection, fault diagnostics, and service monitoring.
CDRs can contain information about recent system usage such as the identities of sources (points of origin), the identities of destinations (endpoints), the duration of each call, the amount billed for each call, the total usage time in the billing period, the total free time remaining in the billing period, and the running total charged during the billing period.VSAs are defined by vendors of remote access servers in order to customize how RADIUS works on their servers.
RAS Overview
The RAS acts as a RADIUS client. It provides a mechanism for generating accounting information in CDRs. The CDRs are transmitted to a RADIUS server in UDP datagrams, using RADIUS Accounting Request messages.
The RAS receives RADIUS accounting messages when different events occur. The event and CDR event trigger list information determines which RADIUS messages, if any, are included, as well as which RADIUS attributes are included. The library adds RADIUS messages to the waiting queue only when the message is ready to be sent. The SIP proxy needs to populate the CDR as session information becomes available so, by the time the session ends, it contains the information necessary to generate all of the messages.
The RADIUS accounting client process manages its queue and a list of servers. The servers each have a UDP connection and manage their own pending message queues. Changes in the state of the server connection might cause interaction with the client process waiting queue.
When RADIUS messages are added to the RAS waiting queue, the RAS sends them to a server based on strategy. If the RAS is configured to transmit all the messages when the session ends, all the messages are sent to the same server. Each session continues logging messages according to the event logging scheme in effect when the session began (for example, when the CDR was created).
The RAS notifies the RADIUS server with Accounting-On/Off messages when the RAS’s entry for that server is enabled/disabled. The response to the Accounting-On message is the RAS’s first determination of RTT, and serves as notification that the server is reachable. Until the Accounting-On response is received, the server cannot send other messages.
RADIUS Accounting Client
The RADIUS accounting client process has a local socket at which it accepts RADIUS messages. RADIUS messages received on the local socket are added to the waiting queue for transmission to a RADIUS server. The waiting queue is a first-in, first-out (FIFO) queue.
The RADIUS accounting client process sends messages to a server queue based on the configuration (servers configured/enable/connected, as well as the strategy). Messages that return from a server (due to server failure/disabling) are first in the FIFO queue.
The RADIUS accounting client process interfaces with the RADIUS accounting servers using the RADIUS protocol with the VSAs outlined above.
The RADIUS server collects a variety of information that can be used for accounting and for reporting on network activity. The RADIUS client sends information to designated RADIUS servers when the user logs on and logs off. The RADIUS client might send additional usage information on a periodic basis while the session is in progress. The requests sent by the client to the server to record logon/logoff and usage information are generally called accounting requests.
RADIUS accounting permits a RADIUS server to track when users commence and terminate their connections. Typical accounting information includes the following:
- Full user name
- RAS identification name or IP address
- RAS port number
- Time connection started
When a client is configured to use RADIUS accounting, it generates an Accounting Start packet describing the type of service being delivered and the user it is being delivered to at the start of service delivery. It sends that packet to the RADIUS Accounting server, which sends back an acknowledgement that the packet has been received. At the end of service delivery, the client generates an Accounting Stop packet describing the type of service that was delivered and, optionally, statistics such as elapsed time, input and output octets, or input and output packets. It sends that packet to the RADIUS Accounting server, which sends back an acknowledgement that the packet has been received. The Accounting-Request (whether for Start or Stop) is submitted to the RADIUS accounting server through the network.
Transactions between the client and RADIUS accounting server are authenticated through the use of a shared secret, which is never sent over the network.
Session Accounting
The RAS client can record SIP, H.323, and IWF session activity based on configuration and a CDR. The CDR determines which messages are generated and determines the RADIUS attributes included in the messages. The RAS client must be capable of sending CDRs to any number of RADIUS accounting servers, using the defined hunt, failover, round robin, fewest pending, or fastest server strategies.
The establishment, failed establishment, change, or removal of a session can trigger RADIUS Accounting Request messages. The RAS might also send notification of its status (enabled/disabled). RADIUS Accounting Request messages include the following:
- Start—Session has started.
- Interim-Update—Session parameters have changed.
- Stop—Session has ended.
- Accounting-On—Creation of a new RADIUS client.
- Accounting-Off—RADIUS client has shut down.
Each session might generate Start, Interim-Update, and Stop messages based on the local configuration when the session is initiated. Each Start message tells the RADIUS server that a session has started. Each Interim-Update message changes the session parameters, and may report the session characteristics for the session to that point. Each Stop message informs the RADIUS server that a session has ended and reports session characteristics.
The RAS has the ability to transmit all RADIUS messages related to a session at the end of the session, regardless of which messages are generated and when they are generated. Some customers might choose this option to reduce the likelihood of the RADIUS messages being logged to different servers, or in different log files on the same server.
The RAS always generates a RADIUS Stop message when the session ends, regardless of the session termination cause. The termination cause and the session characteristics are reported.
Interim RADIUS Records for Recursive Attempts
When the OCSBC routes calls, it performs local policy look-ups that can return several next hops, ordered by preference. This can also happen as a results of an LRT lookup, an ENUM query response, or SIP redirect. To set up sessions, the OCSBC uses—in ordered preference—and recurses through the list if it encounters failures.
You can configure SIP accounting to send RADIUS Interim records when the OCSBC encounters these failures. The interim message contains: the destination IP address, the disconnect reason, a timestamp for the failure, and the number that was called. This feature is enabled by setting the generate-interim parameter to unsuccessful-attempt. Please refer to Appendix B to view the format of an unsuccessful-attempt interim record.
RADIUS Messages
The following table identifies the relationship between the signaling elements and the RADIUS attributes included in Accounting Request messages to the RADIUS server.
| RADIUS Attribute | Data Element | Message |
| NAS IP-Address | IP address of the SIP proxy or the H.323 stack’s call signal address. | Start, Interim-Update, Stop, On, Off |
| NAS Port | SIP proxy port or the H.323 stack’s call signaling RAS port. | Start, Interim-Update, Stop, On, Off |
| NAS Identifier | Value, if any, set in the optional NAS-ID field
for the accounting server that you configure as part of the accounting
configuration. This identifier sets the value that the remote server (the
accounting server) uses to identify the
OCSBC so that RADIUS
messages can be transmitted.
The remote server to which the accounting configuration will send messages uses at least one of two pieces of information for identification: NAS IP address: always included in the accounting message NAS identifier: configured in the NAS-ID parameter of the accounting server; if configured, the NAS identifier is sent to the remote server This attribute only appears if a value is configured in the NAS-ID field. |
| Acct-Session-ID | Either the Call-ID field value of the SIP INVITE message, the callIdentifier of the H.323 message, or RADIUS client information. | Start, Interim-Update, Stop, On, Off |
| Called Station ID | To field value of the SIP INVITE message (a type of message used to initiate a session) or the calledPartyNumber of the H.323 message. | Start, Interim-Update, Stop |
| Calling Station ID | From field value of the SIP INVITE message or the callingPartyNumber of the H.323 message. | Start, Interim-Update, Stop |
| Acct-Terminate-Cause | Reason for session ending (refer to Session Termination session). | Stop, Off |
| Acct-Session-Time | Length of session (time in seconds, or milliseconds if so configured). | Interim-Update, Stop, Off |
Session Termination
Sessions are terminated for reasons that include normal termination, signaling failure, timeout, or network problems. The following table maps RADIUS accounting termination cause codes to network events.
| RADIUS Termination Cause | Event | Message |
| User request | SIP BYE message or H.323 | Stop |
| User error | SIP signaling failed to establish session (accompanied by disconnect cause) | Stop |
| NAS request | RADIUS server disabled | Off |
ACLI Instructions and Examples
This section tells you how to access and set parameters for RADIUS accounting support. To use the OCSBC with external RADIUS (accounting) servers to generate CDRs and provide billing services requires, you need to configure account configuration and account server list.
Accessing the Accounting and Accounting Servers Configuration
To configure the account configuration and account servers:
SIP CDR Stop Time
You can set up your global SIP configuration so the disconnect time reflected in a RADIUS CDR is the time when the OCSBC receives a BYE. Enabling this parameter also means the disconnect time is defined when the OCSBC sends a BYE to the UAS and UAC. Otherwise, the the CDR’s value is based on when the 200 OK confirms the BYE.
The applicable RADIUS CDR in this case is the standard RADIUS attribute Acct-Session-Time, number 46.
Set Acct-session-time attribute to milliseconds
Some accounting features require greater precision. The attribute acct-session-time can be configured to be in milliseconds.
The RADIUS attribute acct-session-time uses seconds as its default. You can set this to a millisecond granularity in the account-config configuration element using the option millisecond-duration. This option setting is required for the RADIUS CDR display, Diameter RF accounting and locally-generated CDR comma separated value (CSV) files behaviors.
Changing to millisecond granularity violates RFC 2866.
