Diameter Manipulation
To configure a diameter manipulation configuration element:
In Superuser mode, type configure terminal and press Enter.
ORACLE# configure terminal
Type session-router and press Enter to access the media-related configurations.
ORACLE(configure)# session-router
Type diameter-manipulation and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# diameter-manipulation ORACLE(diameter-manipulation)#
- name—Enter the name of this Diameter manipulation element.
- description—Enter an optional description for this Diameter manipulation.
- Type done and continue.
