AVP Header Manipulation
- Type avp-header-rules to configure AVP header manipulation rules. The system prompt changes to let you know that you can begin configuring individual parameters.
- name—Enter the name of this AVP Header manipulation rule.
- header-type—Set this to either avp-flag or avp-vendor-id depending on which part of the AVP header you are manipulating.
- action—Enter either none, add, delete, or replace as the action to take after making a positive match on the previously entered match-value.
match-value—Enter the value in the AVP flag field or Vendor ID field to match against.
When matching in the avp flag field, then match-value is interpreted as comma-separated list of enumerated values <vendor,protected,must>. When matching in the Vendor ID field, then match-value is interpreted as 32 bit unsigned integer <1-4294967295>
- new-value—Enter the new value when the match value is found. The resultant new value is entered as the match value is configured.
- Type done to save your work.
