RADIUS Interim record Generation
When refresh requests (UPDATE or Re-INVITE) are sent by the Oracle Communications Session Border Controller , no RADIUS Interim records are generated because session parameters do not change when these requests are sent.
When UPDATE requests are received by the Oracle Communications Session Border Controller , no RADIUS Interim records are generated.
When Re-INVITE requests are received by the Oracle Communications Session Border Controller , RADIUS Interim records are generated if the generate-interim parameter is enabled.
