ACLI Configuration
To configure a session timer profile object:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router
and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
session-timer-profile and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# session-timer-profile ORACLE(session-timer-profile)#
- name—Enter a name for this session timer profile.
- session-expires—Enter the session timer value in seconds you wish this object to use natively.
- min-se—Enter the minimum session timer value in seconds for this object.
- force-reinvite—Leave the default of enabled for the Oracle Communications Session Border Controller to always use reINVITEs for session refreshes. Set this parameter to disabled for the Oracle Communications Session Border Controller to try using UPDATEs for session refreshes.
- request-refresher—Set this to the value to insert in the refresher parameter in the Session-Expires: header on the originating call leg that the Oracle Communications Session Border Controller includes in the 200 OK response message. Valid values are uac and uas.
- response-refresher—Set this to the value to insert in the refresher parameter in the Session-Expires: header on the terminating call leg that the Oracle Communications Session Border Controller includes in the INVITE message. Valid values are uac, uas, none.
Type
done
to save your work and continue.
To apply a session timer profile to a SIP interface:
Type
session-router
and press Enter.
Type
sip-interface
and press Enter.
ORACLE(session-router)# sip-interface ORACLE(sip-interface)#
If you are adding this feature to an existing configuration, then you will need to select the configuration you want to edit.
- session-timer-profile—Enter the name of a session timer profile object you have configured and want applied to this SIP interface.
- Type done to save your work and continue.
