Verify Config Validation
The Oracle Communications Session Border Controller’s verify-config function checks that the value configured in all sip-interfaces’ session-timer-profiles correspond to a configured session-timer-profile name. The following is be generated when this check fails:
ERROR: sip-interface [id] has reference to session-timer-profile [xyz] which does not exist
