Subscription-Id-Type
The Oracle Communications Session Border Controller can send a Subscription-Id-Types AVP to an external policy server:
| Value | Name | Description |
| 0 | END_USER_E164 | Identifier is in international E.164 format (e.g., MSISDN), according to the ITU-T E.164 numbering plan. |
| 1 | END_USER_IMSI | Identifier is in international IMSI format, according to ITU-T E.212 numbering plan as defined in [E212] and [CE212]. |
| 2 | END_USER_SIP_URI | Identifier is in the form of a SIP/SIPS URI. |
To send the Subscription-ID-Types AVP in an AAR, you must add the include-sub-info option in the external policy server configuration element. If this option is enabled, and you do not configure a subscription-id-type in the realm-config, the request line’s Request URI of the received message is sent in the AAR.
You can also set the Subscription-ID-Type on a per-realm basis by configuring the parameter subscription-id-type in the realm-config element to determine the value of the Subscription ID in the AAR.
The default value for subscription-id-type is END_USER_NONE. If the value of subscription-id-type is set to END_USER_NONE, and the external policy server option is enabled to send the Subscription ID AVP, then the Oracle Communications Session Border Controller relies on the request line’s Request URI of the received message.
If the value for subscription-id-type is set to one format, such as END_USER_IMSI, but the request line’s Request URI is set to another format, such as END_USER_SIP_URI, the value of subscription-id-type is used to send in the AAR message.
