If you are adding support for this feature to a pre-existing realm, then you must select (using the ACLI select command) the external policy server that you want to edit.
options—Set the options parameter by typing
options, a Space, the option-name
include-sub-info with a plus sign in front of it, and then press Enter.
If you type the option without the plus sign, you will overwrite any previously configured options. In order to append the new options to the policy server configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
