Subscription ID AVPs in AA-Request Message Configuration To set the Subscription ID AVPs in AA-Request Messages: In Superuser mode, type configure terminal and press Enter. ORACLE# configure terminal ORACLE(configure)# Type media-manager and press Enter. ORACLE(configure)# media-manager ORACLE(media-manager)# Type realm-config and press Enter. ORACLE(session-router)# realm-config ORACLE(realm-config)# If you are adding support for this feature to a pre-existing realm, then you must select (using the ACLI select command) the realm that you want to edit. subscription-id-type—Set the Subscription ID Type included in the AA-Request. END_USER_E164 END_USER_IMSI END_USER_SIP_URI END_USER_NONE Save and activate your configuration.
