RCSE TLS/TCP Re-Use Connections Configuration To configure the reuse-connections option: From Superuser mode, use the following command sequence to navigate to the sip-interface configuration element. ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# sip-config ORACLE(sip-config)# sip-interface ORACLE(sip-interface)# option reuse-connections=latest ORACLE(sip-interface)# Use done, exit, and verify-config to complete configuration.
