RTC Support
This appendix summarizes real-time configuration (RTC) support status for the Oracle Communications Session Border Controller . The table below lists which configuration elements are supported by RTC and which are not.
| ACLI Configuration Elements | Parameter Details |
| Access Control | N/A |
| Accounting Config | N/A |
| Authentication | N/A |
| Certificate Record | N/A |
| Class Profile | N/A |
| Codec Policy | N/A |
| DNS ALG Service | N/A |
| DNS Config | N/A |
| Enum | N/A |
| External Policy Server | N/A |
| H.323 | The following H.323 stack subelement
parameters are not RTC supported in that, if you save and activate a
configuration, calls already in progress are dropped and a reboot is required:
| Host Route | N/A |
| IPSEC | N/A |
| IWF | N/A |
| Licensing | N/A |
| Local Policy | N/A |
| Local Response Map | N/A |
| Local Routing Config | N/A |
| Media Manager | The Media Manager element is supported with
the exception of the following parameters:
| Media Policy | N/A |
| Media Profile | N/A |
| Network Interface | N/A |
| Net Management Control | N/A |
| Network Parameters | The Network Parameters element is supported
with the exception of the following parameters:
| NTP Sync | N/A |
| Packet Trace Config | N/A |
| Q850 SIP Map | N/A |
| Realm Config | N/A |
| Redundancy Config | The Redundancy Config element is supported
| Session Agent | N/A |
| Session Group | N/A |
| Session Router | N/A |
| Session Constraints | N/A |
| Session Translation | N/A |
| SIP Config | The SIP Config element is supported with the
| SIP Feature | N/A |
| SIP Interface | The SIP Interface element is supported with
| SIP Manipulation | N/A |
| SIP NAT | The SIP NAT element is supported with the
| SIP Response Map | N/A |
| SNMP | N/A |
| Static Flow | N/A |
| Steering Pool | N/A |
| Surrogate Agent | N/A |
| System | The System Config element is supported with
| Test Pattern Rule | N/A |
| Test Policy | N/A |
| Test Translation | N/A |
| TLS Global | When configured to support MSRP over TLS, this configuration element is not RTC enabled. If a single TLS profile is used by both SIP and MSRP, RTC changes are applied for the SIP TLS configuration only. |
| TLS Profile | N/A |
| Translation Rules | N/A |
| Trap Receiver | N/A |
